Wiring a Small Utility Trailer
Old Oct 10, 2019 | 10:36 AM
sr73087's Avatar
sr73087
I am possibly rewiring a small utility trailer. The first time I did it I used a harbor freight harness and it worked at first, but now it seems like there is an intermittent open on the yellow wire/harness going to the left turn signal, the rest of the harness works properly. I think its in the harness/plug which I am swapping that out next and have already spent too much time on this frustrating issue. I tested it with a 12V source and it works then I test it again and it doesn't.
Either way, i am finding it may make sense to just rewire the small 4x8 utility trailer vs. spending a few hours messing with it to get nowhere. What brand of wiring do you recommend? After this issue, I don't mind paying more to know it is quality and will last.
Old Oct 10, 2019 | 12:19 PM
06pghescape's Avatar
06pghescape
This is what i used on my 4 x 8 enclosed trailer , 2 years no problems. https://www.etrailer.com/Trailer-Lig...cs/TL29BK.html
Old Oct 10, 2019 | 02:15 PM
Essayon's Avatar
Essayon
I always run a white ground wire to each light, a little extra wire stops the frustration looking for a bad ground.
I had a boat trailer that would rust at the rear cross member every winter and break the circuit.
I ran the wheels off my old Northern folding 4X8 trailer, hauled more with it than my pick-up!
Old Oct 10, 2019 | 02:25 PM
sr73087's Avatar
sr73087
Yea I am kicking myself for not running the ground that way the first time. I agree with you, if I rerun the harness I am running to each light.
Old Oct 10, 2019 | 02:42 PM
Essayon's Avatar
Essayon
I use these on my trailers now. https://www.etrailer.com/s.aspx?qry=7+way+junction+box
It makes it easier to change out the plug and test the wiring. I want to hook up and go, not mess with wiring!
Old Oct 11, 2019 | 08:11 PM
JakeHan's Avatar
JakeHan
Flex loom and individual wires for me, cuz it’s readily available and easy to fix or mod. For lights, I normally use the grommet mount sealed beams or leds, they’re a little more spendy especially if you have to buy the mounts, but no crusty bulb sockets, they just work. If it’s intermittent, make sure it isn’t a crusty connection at the plug, it happens. I usually take the plug apart first and check back from there.
BillBraskey
WTB - Parts & other
Jun 9, 2017 11:55 AM
X_archie
Crossovers
Aug 30, 2013 11:06 AM
EMD_DRIVER
Nov 7, 2008 09:22 PM
BENG0924
Oct 16, 2008 09:56 AM
wreakhavoc
Sep 1, 2007 01:19 AM
