what would you do?
Old Oct 8, 2003 | 08:45 PM
TUFFY's Avatar
TUFFY
what would you do?
I HAVE A 1980 F250 WITH A 351-M THAT I AM GOING TO REBUILD IHAVE HAD THE CRANK TURNED TO .10 MY QUESTION IS SHOULD I GET A 400 CRANK AND PISTIONS WHICH I CAN GET FOR FREE AND PUTTHEM IN THE 351 OR SHOULD I STICK WITH WHAT I HAVE ?IM SURE THAT I WILL HAVE TO HAVE THE 400 CRANK TURNED
Old Oct 9, 2003 | 09:09 AM
beartracks's Avatar
beartracks
I would upgrade to 400 for sure. Are the pistons new? By the way all caps is a form of shouting in the forums.
Old Oct 9, 2003 | 06:59 PM
TUFFY's Avatar
TUFFY
Thanks for the responce didn't realize that i had used all caps in my post sorry Dave
Old Oct 14, 2003 | 10:51 PM
fordeverpower's Avatar
fordeverpower
i would go for the 400 crank and pistons if you have the motor out or in pieces otherwise stick with the 351. you might need new pistons though.
Old Oct 15, 2003 | 09:32 PM
derekyorktown's Avatar
derekyorktown
Re: what would you do?
how did you manage to snag the crank and pistons?? this is what i need.
Old Oct 16, 2003 | 09:49 AM
dogdays's Avatar
dogdays
TWO SIMPLE RULES TO LIVE BY:
1. There's no replacement for displacement. Or, there's no substitute for cubic inches.
2. If some's good, more's better and too much is just right.
By application of these simple rules you will be led to the 400 crank and pistons. Be sure to get the straight dope on which pistons to buy from the more experienced members of this forum.
R.
