87 plastic headlights
Old Mar 31, 2001 | 09:00 PM
dugal's Avatar
dugal
The plastic headlight lenses on my 87 f150 look like they have been sandblasted from road wear. Does anyone know how to polish the plastic to like new again? I guess I could buy some new ones, but not sure of the cost. A little elbow grease does not bother me either. I thought maybe some wet 600 paper, then wet 1200 paper, then polishing compound. Any ideas?
Old Mar 31, 2001 | 11:25 PM
PAUL_2's Avatar
PAUL_2
I dont think sanding will help , it will likely make it worse . If they are trashed you may be able to find some salvage yard ones in better condition .
Old Apr 1, 2001 | 03:34 PM
Franklin2's Avatar
Franklin2
These new plastic headlights are one of the many "new and improved" ideas from carmakers. When's the last time you had to replace a glass headlight because it was fogged up, scratched up etc. Welcome to the "privilege" of owning a newer vehicle.
Old Apr 1, 2001 | 03:39 PM
dave89f150's Avatar
dave89f150
I had the same problem on my 91 Mustang. I used 1200 grit sandpaper(I believe)and some water to clean off all of the grime. Then, I used some stuff called "scratch out" by KIT. It is a scratch and haze remover. I polished them by hand with the stuff (same method as waxing) and then buffed them out by hand. Finally I put a coat of wax on them. They really looked good for awhile, but they are ready for another treatment. A buffer would make it a lot easier.
89 F150 4x4 300/4 speed 33.12.50 w/Rancho lift 3.55 gears
82 Mustang GT 302 C4 + nitrous=FAST
91 Mustang GT basic bolt ons- GM Eater
Old Apr 1, 2001 | 11:18 PM
fatforty's Avatar
fatforty
You should be able to sand them with 1,000 grit and polish them with 3m micro finishing compound or equiv. when you sand make sure to use lots of water it saves paper and makes a smoother job. John
Old Apr 2, 2001 | 11:56 AM
jim henderson's Avatar
jim henderson
Yeah, I like the new plastic light assemblies too. When they break, instead of replacing a $10(I'm being generous) bulb, you get to replace a several hundred dollar assembly. Plus in the great NorthWet, we get algae growing in our lenses if we are lucky.
I recommend you talk to a local plastics supplier. There are lots of hobby and home "do it yourself" type stores out there who have all the right stuff to make your plastic lenses shine like new.
Jim Henderson
Old Apr 2, 2001 | 07:35 PM
mjb1962's Avatar
mjb1962
