Power steering box
Old Oct 7, 2019 | 12:02 PM
460me's Avatar
460me
Power steering box
79 f250 2 wheel drive 460. It's leaking at the bottom seal. Readhead to the rescue. Trying to get a head start on ordering, Anybody know the make and model, or should I just call them up.Don't want to order the wrong one. Thans
Old Oct 7, 2019 | 12:04 PM
fordguy2100's Avatar
fordguy2100
Their website has the specifics for each part they sell. Just find the one that Matches your truck. If you don't trust yourself, give them a call.
Old Oct 7, 2019 | 12:08 PM
niko20's Avatar
niko20
Speaking of this topic, just curious, how much work is it to replace the steering box?
Old Oct 7, 2019 | 06:51 PM
John89's Avatar
John89
It wasn't too bad on ours. 4wd, PS though. You will definitely want a helper.
Old Oct 7, 2019 | 10:33 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 460me
79 F250 460. It's leaking at the bottom (as usual, the sector shaft) seal. Redhead to the rescue. Trying to get a head start on ordering,
Anybody know the make and model, or should I just call them up. Don't want to order the wrong one.
D9TZ-3504-A .. Ford/Saginaw P/S Gear Box / ID number (1979): SPA-BX or SPA-CC or SPA-CN
Edit: 1974/79 F100/350 2WD
Old Oct 7, 2019 | 10:39 PM
azroxx's Avatar
azroxx
D9TZ-3504-A .. Ford/Saginaw P/S Gear Box / ID number: SPA- BX or SPA-CC or SPA-CN
1973/79 F100/350 2WD
Thanks for that info Bill! I went thru all the moves this weekend trying to see what was up with my '74 and found a leak and where the steering shaft goes into the box and a large amount of play before the pitman started moving.. I do not want to pull and rebuild, will just order a new one using your part info.
Old Oct 7, 2019 | 10:53 PM
NumberDummy
TYPO! Applications should read 1974/79 F100/350 2WD
Old Oct 7, 2019 | 11:40 PM
jakeharp's Avatar
jakeharp
Blue top
Send valve, cylinder and box to blue top
Gordon M
13
Sep 16, 2018 10:36 PM
4wydnr
Jan 5, 2011 09:57 PM
Alex from GA
Nov 2, 2005 08:08 PM
1stF250
Jun 14, 2004 12:49 AM
rok crusher
Nov 25, 2002 11:06 AM
