Vvt system issue
- replacing the solenoids is likely just a waste of time and money at this point; as the problem likely is further downstream.
- the only real downstream component is the cam phaser itself
- the phasers themselves usually don't generate a lot of noise when they fail, but will cause a lot of the issues you've described. Essentially, with the phasers not working properly, the cams are out of time - causing the misfires.
- the bank over retarded code is usually a good indication as well that the phasers aren't doing their thing.
If it were to roll into my shop, I would usually recommend the following work be done (keep in mind, this is a recommendation - the choice is ultimately yours)
- Replace entire timing set; including tensioners and guides; it's usually just a matter of time before they become an issue
- Replace both phasers; you're already at that point
- Replace oil pump; it's 5 more bolts once you're that far in
- based on inspection; sparkplugs
- water pump is an option, as you're right there
Parts list:
- timing set (with the iron tensioners, not plastic)
- cam phasers
- oil pump
- timing cover gasket set
- valve cover gasket set
- intake manifold gasket set (removal makes the job considerably easier)
- oil/filter
Optional:
- spark plugs
- water pump
- coolant
I've gotten pretty good at them, can usually have everything done in one day - as long as the plugs cooperate... If they haven't been done before, it may induce large amounts of cursing. That's why most mechanics have invested in all the special tools for removal....
Parts list:
- cam phasers
- oil pump
- oil/filter
Optional:
- spark plugs
- water pump
- coolant
The VVT system is fairly simple, mechanically - the solenoid valves port oil through the front cam bearing area into the center hub of the cam phaser; adjusting the cam timing. If they aren't porting oil to the phaser, it just dumps it into the timing cover. Same oil pressure actuates the cam chain tensioners; there are ports on the back of the tensioner to facilitate that. I actually rebuilt a 4.6 not too long ago, and someone had put the tensioners on the wrong side and it ended up starving the passenger side cam - bad things occur in that case...
I have absolutely zero experience with the lockouts; the anecdotal evidence I've seen says that there will be some drivability issues; particularly at the low end. I'd much rather invest in making the system work right. Not sure if any sort of tuner is needed to eliminate CEL issues - which may be an inspection concern depending on where you live.
There are those that insist that OEM parts is the only way to go; but I have had pretty good luck with using aftermarket parts. The key is to stick with reputable aftermarket parts; not just the cheapest amazon parts to be found.
I use Cloyes timing components whenever possible - they have kits available with both the plastic and iron tensioners.
Of the dozen or so times I've done this, I've had precisely one failure out of the box with the Dorman phasers - and it was replaced under warranty (I had to eat a bit of labor to make it right for the customer, but that was my choice to make it right).
Oil pumps, stick to Melling or Sealed Power
If you try and save money and go with the cheapo ebay kits, you're playing with fire in my opinion.
As far as balancing costs with a new engine; only your wallet can answer that question...
- If you buy a used engine, chances are it would need all that work anyway; not good economical sense
- A reman engine will have all the new parts and a warranty, but will incur additional costs with the job - plan on possibly replacing exhaust manifolds (cracking), new plugs, intake gaskets, water pump, etc. - plus the labor involved. Just for reference; my cost (commercial account at O'Reilly) for a reman long block is just shy of $3700 - and that's before any shop markup. I'm a small independent; I would mark it up around 30%, then charge ya $450 in labor - plus all the other components. So I threw a quick parts list together - for a new engine, installed, with the above noted components added to it; my cost estimate to you would be just shy of $6k for parts/tax/labor.
By comparison, doing the complete timing job as I noted above averages between $1600-1800 for parts/tax/labor; depending on the specific parts needed and if the solenoids need done.
Please keep in mind that those are my prices, at a independent shop in BFE Ohio - depending on your location, things will vary greatly.
Good luck, and hopefully you can find a shop willing to help you get it right soon - I recently had a potential customer come in with similar complaints; he told me the local dealer would only offer a complete replacement engine to the tune of $8k+ - so he was seeking answers
