Cruise control help
Old Oct 5, 2019 | 06:24 PM
Calveryc's Avatar
Calveryc
Cruise control help
I have a 79 f250 and the cruise control suddenly quit working. Any ideas of commonly failure points I should check?
Old Oct 5, 2019 | 07:40 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Fuse, dump valve, vacuum leaks, cable, slip rings, and switches.
I assume the issue is it will not engage.
Old Oct 5, 2019 | 11:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Calveryc
I have a 79 F250 and the Speed Control suddenly quit working. Any ideas of commonly failure points I should check?
Speed Control switches located in the horn pad (factory installed) or clipped to the T/S handle (dealer installed)?
Old Oct 6, 2019 | 12:20 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
yepper Bill...... Thanks for all your posts.... I just wish more folks would listen to you and yeah most the time I Find switches
ford9303
Apr 30, 2014 10:21 AM
silverxlt
2004 - 2008 F150
Mar 3, 2006 08:36 PM
putzhall3
Electrical Systems/Wiring
Feb 21, 2004 05:14 PM
jeepin
Aug 17, 2003 08:13 PM
