Preferred axle ratio for 7.3?
I am leaning towards ordering the 373 gears and 18 inch tires. According to one poster who did the math that because of the smaller diameter tire compared to larger tires the tuck thinks/operates like it has 3.89 gears.
It was calculated that guys who have 4.33 and put on larger tires effectively reduce their ratio to 4.10.
I think my lawn tractor has those...
well I failed to mention that I am a farmer and a volunteer fire fighter. I’m always in my truck so I wanted to get the super duty for all the room, comfort and power...
yes, shorter gears are higher numerically. Longer gears are lower numerically. this is in reference to how gears that are higher numerically like the 4.30's move through rpms quicker or shorter than gears that are lower numerically like 3.73's which take longer to move through rpms relative to the same gear ratio in the transmission.
Higher gears = lower numerically (3.31, 3.55, etc...)
Lower gears = higher numerically (4.10, 4.30, etc...)
Understand that the manufacturers (Ford in this case) all program their automatic transmissions to shift early and keep the engine at the lowest possible RPM for emissions and mileage ratings. Lower gears will help put more power down in every gear before needing to downshift.
One benefit of the 10-spd trans, is that 10th gear is geared higher than the old 6-spd's 6th gear. Meaning identical trucks...tire size, axle gears, etc....the 10-spd truck will turn lower RPM's than the 6-spd truck. I say this is a benefit, because you can choose 4.30 gears, and have better highway mileage, with all the other benefits of the lower gears everywhere else.
In my 6-spd/4.30's, I'm turning ~2200rpm at 72-74mph. The 10-spd will probably be around 2000rpm at the same speed.
Guys I work with are reporting similar fuel economy numbers, but the 7.3 guys seem happier with the power.
Are the 6.2 and 7.3 running the same gear ratio and the 10 speed tranny?
Could I get another 1/2mpg with the 3.55/3.73? Maybe. But I'd much rather have the power of 4.30's available to me.
Dad, a mechanic for 50 years, always said "Get the biggest engine and lowest gears available, and you will never wonder 'what-if?'" Diesel was not an option for me, so I got the biggest (only) gas engine available at the time I ordered my truck.
If you live in the flatter states, it becomes less of an "issue", if you can call it that.
And again, the 10-spd should get a touch better mileage yet...
no, all of the 6.2's had 6 speeds and 3.73's. 2 of the 7.3's are 3.73 and 1 is 4.30. from what I have heard there is only about 1mpg difference between the 2 gear sets with the 7.3.
From the 2020 brochure.
