smog Garbage
Old Oct 8, 2003 | 05:22 PM
Bhanna4d's Avatar
Bhanna4d
smog Garbage
Hey,
Is it possible to get a head that does not have the air holes for the smog pump and just get rid of all that crap completely?
Old Oct 9, 2003 | 08:39 AM
montster's Avatar
montster
I am looking at doing the same thing. that way I can move my altenator up to the pump bracket and get it farther from the water,If you look in the 4x4 forum under relocating alt and post a reply when somebody replies there you will get a notification,maybe the info will help you too.
good luck and let me Know how you do
Montster
Old Oct 9, 2003 | 03:56 PM
Redneck-Cowboy's Avatar
Redneck-Cowboy
Right now on my 86 I've managed to eliminate all that smog junk(including the pump) off my engine, by taking out lines, plugging lines into the carb, plus I have now cats. Pretty easy job actually, just rip off the pump, look where your lines go, decide if they need to be there, otherwise screw a bolt, rag, piece of wood, etc. into them, actually on one of mine off the carb I have a 20 gauge shotgun shell stuck over it with baling wire for a clamp. Now I see you have an 89, fuel injection can be tricky sometimes w/ computer sensors and stuff, plus if you eliminate the pump and have a serpintine system you have to find a new belt length. Otherwise for montster, it can be done in under an hour, my alt. is still in the same place though.
Redneck-Cowboy
