I have a 2010 Ford F-150 4.6 V8 and it’s Vin #8. I have changed spark plugs, coils, all injectors, fuel pump, and all o2 sensors. My truck is still running rough. It will idle at 500 rpm and dip down, then back up and will sometimes shut off. It’s getting frustrating. Please help! Seems like it isn’t getting enough air.
Reason: Added my vehicle in the post
HINT/TIP: Rather than playing 20 questions, put your -COMPLETE- vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, modifications, etc., etc.) in your signature -OR- provide it in your posting(s).
I did some digging and on 2009 and 2010 ford trucks, The solenoid purge valve for the evap systemIs different in these two years and they are known for going bad, so if you are experiencing evap and lean codes, try that sensor out
