Random wire i found.
Old Sep 27, 2019 | 04:08 PM
86bullnose4x4's Avatar
86bullnose4x4
I found this random wire hanging down next to my oil pan on my truck and I can't figure out where it goes or what it is for. Does anyone know what it is? My truck is an 86 supercab 6.9 c6 trans 4x4.
Old Sep 27, 2019 | 04:56 PM
tjc transport's Avatar
tjc transport
i ain't rite
block heater plug.
90Ford73's Avatar
90Ford73
Thats for your block heater
Old Sep 27, 2019 | 05:05 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
and depending on your engine block Serial Number you may just want to leave it disconnected too.
Old Sep 27, 2019 | 07:37 PM
86bullnose4x4
Are there two types of block heater plugs? Because I have one tucked under my front bumper.
Old Sep 27, 2019 | 07:55 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
the one under the front bumper is probably the one to plug into a 117 VAC duplex receptacle AKA 110 wall plug
and on the block heaters themselves there are several different style plugs......... depending on who made the heater....
as an example.... ==>> https://www.auroragenerators.com/pro...s-block-heater
Old Sep 27, 2019 | 08:02 PM
86bullnose4x4
Oh okay was many problems with the stock heater in 86? And i probably won't be needing it anyway living up here in North Georgia.
Old Sep 27, 2019 | 08:46 PM
90Ford73's Avatar
90Ford73
Iirc the block casting was too thin/not strong enough and using the block heater would result in the block cracking around the heater and leaking coolant.
Old Sep 27, 2019 | 08:56 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
ya depends on the engine SN if it had that issue... just as 90Ford73 said... and yeah I doubt you need it in Georgia... IF you must have one I think the better option is in the lower RAD Hose... they also make Dipstick Heaters to keep the oil warm...you folks do get some good freezes but a blanket over the front end in your case is plenty fine..... Garage is always best
Old Sep 27, 2019 | 09:52 PM
86bullnose4x4
Sounds like the better and cheaper route. I appreciate all the feed back from y'all thanks a million!
Old Sep 28, 2019 | 06:01 PM
irhunter's Avatar
irhunter
Wow...so, that is what the underside of one of these trucks is supposed to look like!
What's next from Georgia...an un-rusted rear fender?
Roy
Old Sep 28, 2019 | 07:05 PM
86bullnose4x4
Roy
I bought the truck in California a month before my wife and I moved back home to Georgia. And thank God we left... This Georgia boy didn't belong there ha
Old Sep 28, 2019 | 08:38 PM
irhunter's Avatar
irhunter
Well, I have seen some great rust-free trucks in both Georgia and Cali.
Not up here in Rust Central.
Roy
Old Apr 14, 2020 | 03:50 PM
DieselRugger's Avatar
DieselRugger
Anybody know where I can find one of those connectors? The wires were pulled right out so I've got the orange rubber connector, but no ability to rewire it.
Any ideas?
Old Apr 14, 2020 | 04:04 PM
irhunter's Avatar
irhunter
This?
Amazon Amazon
Roy
