wheel bolt torque.
Old Sep 27, 2019 | 11:47 AM
jniolon's Avatar
jniolon
old and in the way
wheel bolt torque.
Wondering what I should torque my lug nuts at. Mustang II susp. and hubs ... brackets and Chevelle calipers. Prime 505 wheels,
snugged them up with impact, but just enough to hold the rim tight
My suburban torques to 140#... where can I find this info ??
Old Sep 27, 2019 | 12:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Both of my modern vehicles with 5-lug aluminum wheels get 100 ft-lbs., with a re-torque after 25 miles or so.
Old Sep 27, 2019 | 12:52 PM
52 Merc's Avatar
52 Merc
Here's a chart from a 72 Ford truck service manual I found online. I was always told 1/2" studs get 90-110 ft. lbs. 7/16" GM studs get a little less. I've always torqued to 100 and never lost a wheel yet.
Old Sep 27, 2019 | 02:16 PM
jniolon's Avatar
jniolon
old and in the way
not worried about losing one, worried more about warping the rotors. I'm using aluminum wheels and what I found is 70-85 for alum 90-100 for steel
Old Sep 27, 2019 | 05:52 PM
artscott61's Avatar
artscott61
Veteran: Navy
John I have always used 100 tt lbs on all of mine. If the sequence is used the problem should not occur .Even with steel wheels I do not torque to max on the first go round I torque to 75 then finish with 100. My way of thinking is that helps seat the wheel against the rotor then go all the way. I have only lost two wheels that way.(just kidding). OH!! by the way only eleven days for me to leave for CTC.
Old Sep 27, 2019 | 08:16 PM
56panelford's Avatar
56panelford
The Centerline aluminum rims I had on my panel were only recommended to be torqued to 75 ft lbs and no more.. my steel smoothies I torque to 80 ft lbs
Old Sep 27, 2019 | 08:50 PM
jniolon's Avatar
jniolon
old and in the way
I'm going with 80#... that's what my wheel dealer recommended.
We'll be down on the 10th... I don't know if I have your cell.. mine is 205-213-5016
sailorman3
Apr 24, 2011 10:38 PM
bigred00
Mar 15, 2009 11:33 PM
670johndeere
Jun 6, 2006 07:52 PM
samckernan
Sep 3, 2004 10:28 AM
blueford85
Feb 13, 2004 11:12 PM
