Can anyone tell me what this piece is called? I doubt they make new ones, but does anyone know if they are the same on other models like F-150 vs F-250?
I need to replace this one on my highboy chassis and I have a F-150 parts truck that I may be able to use this piece off of. My searching is not turning up much information because I don't know what to call it.
I've always called them " gussets " but I've head them called " fish plates " . I really doubt they're reproduced.
Too bad you're so far away I see nice high boy frames go for scrap from time to time. it's possible you could get someone to cut what you need out before they haul it away.
2) C7TZ-5B055-A .. Frame Rear Side Member Reinforcement - Right/Left is the same / Obsolete
1967/77 F250 4WD ~ No Ford dealer or obsolete parts vendor has any, none on ebay.
1973/79 F100/150 4WD is different and they're right (D3TZ-5B055-A) & left (D3TZ-5B055-B) specific.
Glad I didn't waste an afternoon grinding them off my parts truck since it looks like they are indeed different. I may be able to get them off the highboy frame I took the cab mounts off of if they are in better shape.
