E4OD Torque Converter Unlocking
Old Oct 3, 2019 | 10:40 AM
osu711's Avatar
osu711
No it didn't go back to first on its own,as per my deceleration it went back to first normally.
As per codes the only code that was slightly concerning was P0605 but I also have a chip on this truck so I wonder if that was causing the code
rode around with a modis hooked up to it for close to a half hour and couldn't get anything abnormal to happen
I also changed my multifuncion turn signal switch too, I read somewhere on here that the multifunction switch can cause weird issues as well and as clapped out as mine is getting i figured why not change it . Its been 3 days so far and everything has been ok so far. If this doesnt solve my issue I wonder if my pcm is no good or the speedometer is messed up as I also noticed a slight bounce around 40MPH in the neede.
Knock on wood.. I will keep everyone posted.
Old Oct 3, 2019 | 10:41 AM
osu711's Avatar
osu711
Originally Posted by quesey
My truck did that once. Found that the trailer wiring back by the plug in had some wires lose
Took me forever to find it.
Good luck
I looked back there already,
I rewired the plugs last year with all new plugs
Old Oct 10, 2019 | 06:30 AM
osu711's Avatar
osu711
Well I believe the multi-fumction switch was my issue. Its been perfectly fine for a week now, Im going to declare this one solved knock on wood. Thank you all for the help
Old Oct 10, 2019 | 08:14 AM
fordman67's Avatar
fordman67
Awesome to hear!!! File that one in the memory bank here.
Jrock909
Feb 4, 2009 05:29 PM
big inch
Jan 3, 2007 10:38 AM
pikiluvi
Nov 17, 2003 03:50 PM
