What’s my engine?
Old Sep 22, 2019 | 06:47 AM
Aussie__Dave's Avatar
Aussie__Dave
What’s my engine?
Rookie question - can someone tell visually if the engine in my old F-100 is 351 Cleveland (due to the 8 bolt valve covers)? Or is the engine something else? Thanks in advance
Old Sep 22, 2019 | 09:18 AM
Conanski's Avatar
Conanski
The Cleveland was never factory installed in a truck but at this age it's possible to find anything under the hood. The 351c and 351/400M are very similar and use some of the same parts but the 351c block is physically smaller and it has a removable timing cover like the windsors whereas it is cast into the block on the M.
Old Sep 22, 2019 | 09:35 AM
Diesel_Brad's Avatar
Diesel_Brad
If you look at his name (Aussie dave) and the righthand drive it should be a give away. By the 4 bottom bolts on the valve cover it at a C or M engine
Old Sep 22, 2019 | 10:19 AM
Conanski's Avatar
Conanski
Yeah I thought he might be down under, his post is also in the wrong forum but that is something for the mods to sort out.
Old Sep 22, 2019 | 12:47 PM
Scndsin's Avatar
Scndsin
At any rate, what year is the truck?
(Never-mind, profile sez 83.)
Old Sep 22, 2019 | 01:50 PM
Aussie__Dave
Thanks for the speedy replies. Appreciate your knowledge and experience.
The truck seems to have bits from the seventh and eighth generations, so it’s a somewhat hard to assign a forum.
I was guessing a 351C, but wasn’t sure if it was a 302C that I gather was unique to Australia and if there was a visual trick I was missing. My mate suggested I pull a plug and put the dipstick/a straw in the bore with the piston on TDC. Mark the dipstick.Turn the engine over by hand. If 3 inches?, it’s 302. If 3.5 inches?, it’s 351.
Cheers again
Old Sep 22, 2019 | 03:16 PM
Scndsin's Avatar
Scndsin
Is it running on LP?
Looking at the exhaust sez it's something 335 series headed.
Old Sep 22, 2019 | 03:47 PM
Aussie__Dave
Yeah mate, it’s got LPG connected ... for now 😉
Old Sep 22, 2019 | 04:38 PM
torq'ta 5 8's Avatar
torq'ta 5 8
you could check your mechanical fuel pump block-off plate, if bolts are top(12), bottom(6) =cleveland, if side(9) by side(3) windsor
Old Sep 22, 2019 | 05:28 PM
Scndsin's Avatar
Scndsin
How bout if the T-stat exits the block or intake manifold?
afatbastured
Aug 29, 2017 07:46 PM
Jocaren
Ford Truck Parts for Sale
Sep 24, 2013 09:53 PM
jgcrisall
Aug 22, 2012 09:41 PM
run6.0run
Jun 25, 2012 01:41 PM
jpb222
Nov 12, 2009 03:06 PM
