Fuel tank selector valve
Old Sep 21, 2019 | 08:02 PM
Rotorpilot's Avatar
Rotorpilot
I need some help. My 1986 F250 460 will not switch tanks. Could someone tell me where the selector valve is located. My truck has a manual fuel pump. Also when refuelling the gas keeps gushing out of the tank. Could that be a vent and if so where is that located??
Thank you for all your help
Old Sep 21, 2019 | 08:05 PM
Franklin2's Avatar
Franklin2
The switching valve is on the driver's side frame rail, approx under the door area on the inside of the frame.
If you are having trouble filling the tank at the station, you need to check the vent hose inside the fill hose. There is a smaller pipe inside the large fill pipe, and if this pipe is dislodged or someone has taken it out, that can cause the problem you are having.
Old Sep 21, 2019 | 09:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
9189 is the fuel tank selector valve:
Old Sep 22, 2019 | 10:37 AM
Rotorpilot's Avatar
Rotorpilot
Fuel tank selector
Thank you so much for the info. I ordered the correct one Tasca Ford. I do have one last question. Does it require a special tool.to remove the fuel lines ?.
Old Sep 22, 2019 | 11:09 AM
NumberDummy
This valve has been a notorious POS since day one!
E5TZ-9189-B .. Fuel Tank Selector Valve - 6 ports / Marked: E57B-9F271-BA or E67B-9F271-AA / Available from Ford
Misc applications: 1985/86 E250/350 & F250/350 I-6 & V8's (gas) over 8500 lbs. GVWR // 1985/86 Ranger 2.3L 4 cylinder gas and diesel // 1985 Ranger 2.8L V6.
1985 E250/350 & F250/350 6.9L diesel over 8500 lbs. GVWR // 1986 E150/250 302.
MSRP: $226.07 // autonationfordwhitebearlake.com online price: $149.20.
Old Sep 22, 2019 | 12:31 PM
Franklin2's Avatar
Franklin2
The fuel lines on the valve are a male nipple with a bump or ridge made into it. The lines themselves are female with a o-ring inside. They slide up on the smooth male part on the valve and then a horseshoe keeper slides over the female line fitting and this locks it, since the horseshoe will be behind the bump or ridge. The horseshoe looks like the picture below, you just take a small screwdriver and pry it out and pull it out completely, then the fitting will slide off.
Old Sep 24, 2019 | 07:46 PM
Rotorpilot's Avatar
Rotorpilot
Horseshoe clips
I am going to replace my fuel tank selector valve . I got the new valve but would like to.have a few extra hose clips available just in case. Does anyone know if they are available and do they have a parts number ??
Old Sep 25, 2019 | 07:58 AM
FuzzFace2's Avatar
FuzzFace2
I would first try the local parts stores and if not then maybe LMC truck.
Dave ----
Old Sep 26, 2019 | 09:03 PM
ctubutis's Avatar
ctubutis
The HELP! section at a local store might have some.
Old Sep 29, 2019 | 05:06 PM
Rotorpilot's Avatar
Rotorpilot
460 Manifold
Does my 1986 F250, 460 have a SQUARE BORE or SPREAD BORE intake manifold. I need to get the proper adapter / spacer to install my Edelbrock 1405 carb.
Thanks for the help.
Old Sep 29, 2019 | 05:27 PM
FuzzFace2's Avatar
FuzzFace2
If you don't know what you have then how do you know you need an adaptor?
Can you take a picture of the intake with out the carb and the bottom of the new carb?
Dave ----
Old Sep 29, 2019 | 08:57 PM
Rotorpilot's Avatar
Rotorpilot
Carb and adaptor
I am going to remove the EGU adapter off the manifold. Edelbrock recomends a 1" adapter and then the the carb. I needed to know weather my manifold. Is a square bore or spread bore manifold so I can get the right adapter. I want to have everything I need before I start removing the carb. It's a 1986 F250 460. Any help would be appreciated.
jimandnena
Jun 15, 2014 10:47 AM
Nick.Pence
Aug 19, 2012 12:10 PM
bad2thebone
Jul 5, 2009 11:43 PM
89 blk 250
Oct 13, 2006 07:53 AM
FOSE88
Oct 5, 2006 10:55 AM
