65 F100 Decode Please
Old Sep 19, 2019 | 07:08 PM
1965GTFB's Avatar
1965GTFB
F10DR687878
129 B F100 381 N 08
5000 172 4000 and the last # is partially wiped out from the door dragging in the opening soonly the last digit of a 2 is left.
Thanks
Old Sep 19, 2019 | 09:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 1965GTFB
F10DR687878 / WB: 129 / COLOR: B / MODEL: F100 / BODY: 381 / TRANS: N / AXLE: 08 / MAX GVW LBS: 5000 / CERT NET HP: 172 / RPM: 4000 / DSO: 72
F10 = F100 2WD
D = 352 2V
R = San Jose CA Assembly Plant.
687878 = 1965.
129" Wheelbase.
B = Caribbean Turquoise.
F100 2WD, 5000 lbs. GVWR
381: 3 = Medium Green Crush Vinyl & Medium Green Wicker Pattern Vinyl / 81 = 81A Standard Cab.
N = New Process 435 4 Speed Manual Transmission.
08 = Ford 9" Rear Axle / 3.50-1 / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Sep 19, 2019 | 10:12 PM
1965GTFB's Avatar
1965GTFB
Thanks ND. Can always count on you.
masterqi
Feb 23, 2009 03:21 PM
mike58f100
Oklahoma Chapter
May 25, 2002 05:27 PM
