Sponsored by: Real Truck
A/C cabin filter.
Old Sep 19, 2019 | 05:53 PM
Bryson Check's Avatar
Bryson Check
A/C cabin filter.
Hello, I have a 2001 Ford F-250 Super Duty crew cab, lariat 4x4 with a 7.3 Powerstroke that has 287xxx. I just replaced the ac and all it's components but it's still not blowing very well inside the cab. The condenser has ice on it and the cab stays barely cool so I'm thinking it might be the cabin filter. Question is : Where is it located? I've pulled the glove box apart almost to the firewall and haven't had any luck. Any ideas?
Old Sep 19, 2019 | 05:55 PM
ExDakotaOwner's Avatar
ExDakotaOwner
Is it under the glovebox?
Old Sep 19, 2019 | 06:00 PM
Bryson Check
Not that I could see, that's why I'm so confused because everyone I've asked says it'd most likely be under it or behind it but I never saw it.
Old Sep 19, 2019 | 06:01 PM
ford390gashog's Avatar
ford390gashog
A iced over condenser is from lack of air flow or improper charge. There isn't a cabin filter.
Old Sep 19, 2019 | 06:02 PM
T diesel's Avatar
T diesel
Super duty cabin filters started in 2017.
Old Sep 19, 2019 | 06:41 PM
Bryson Check
That's good to know. What could cause restricted air flow?
Old Sep 19, 2019 | 09:31 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Clogged radiators or even a bad fan clutch
Old Sep 19, 2019 | 10:02 PM
Bryson Check
Good point, what I find strange is that the a/c didn't really work but when it did, it blew out ice cold and with everything it had to give for about 3-10 minutes depending on how fast I was going but then it gave out and it was unknown if or when it would work again or for how long. I was told that the compressor was going out so I changed it out with the clutch assembly, orifice tube and air dryer. We vacuumed out the system and then using the gauges we charged it and since then it works all the time when I turn it on but it's nothing like it was before when it only worked for a few minutes. What should I look at changing out next to get it to work properly?
Old Sep 20, 2019 | 06:21 AM
projectSHO89's Avatar
projectSHO89
Or a compressor clutch that is not cycling off.
Your troubleshooting "procedure" as it appears to be based on guesswork instead of analysis of the system.
Hook up the gauges and WATCH the system. Does the low side approach the 20-25 psi point and then cycle the compressor off?
When you charged it, did you accurately weigh in the charge or just guess at how much was put in?
Oh, by the way, condensers NEVER ice up being as they're out there in front of the radiator. The "thing" in the dash is called the evaporator.
Ultratravler
6.7L Power Stroke Diesel
Jan 13, 2019 10:50 AM
crazer42
Jan 31, 2010 06:01 PM
2004 xlt 5.4
2004 - 2008 F150
Jul 12, 2009 10:01 PM
alfama351
Dec 24, 2004 08:27 AM
