Diff/transmission pairing for '64
Old Sep 17, 2019 | 09:42 AM
Blaine D's Avatar
Blaine D
8th Gear
Hi all, brand new user here.
So I acquired a '64 F100 with 4 speed manual, purchased new by my great grandfather, and have decided I may as well throw my lifes savings at it. Current issue is the rear end, it has a Dana 44 (I believe) with 4.11 that needs some work and both brakes are in need of repair. I'm looking to swap to a Ford 9" with 3.54 or similar, hopefully a complete axle assembly. Here's my question; I've found a 1965 parts chassis with a 9" for $150 that has 3 speed trans and IL6, but the owner does not know the ratio and is unwilling to check, it's about 4 hours away. Was there a "normal" diff ratio that would have come with a truck of this sort?
Old Sep 17, 2019 | 03:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Here's my question; I've found a 1965 parts chassis with a 9" for $150 that has 3 speed trans and I-6, but the owner does not know the ratio and is unwilling to check, it's about 4 hours away.
AXLE code stamped on the 2nd line-far right of the Warranty Plate, riveted to the left door face below the latch.
9" axle ID tag located at approx. 5 o'clock under one of the studs/nuts that retain the carrier (pumpkin) to the housing. By now, many of these tags are missing.
9" with 3 M/T ratio would likely be 3.50, 3.70 or 3.89. // 3.25 common 9" ratio with A/T
Note: If it's a Dana rear axle, it has Limited Slip and all Dana's have an inspection cover. The F100 9's from this era do not have Limited Slip and there no inspection cover on any 9.
Old Sep 17, 2019 | 06:58 PM
john jamieson's Avatar
john jamieson
Since you really don't know the condition of the other rear end, Look at having yours rebuilt Weather it's a dana 44 or a ford 9" you will be better off rebuilding either one before putting it in your truck. I had My dana 44 go out while I was going to work. The pinion gear had broken some teeth. I found pitting on some areas of the ring gear. Of all the parts on my truck I had planned on rebuilding, I never thought about the rearend. Out of sight , out of mind.
47duallyFL
1947 and Older Ford Trucks
Oct 22, 2013 06:37 AM
civicmindeddogooder
29
Jan 16, 2013 09:41 PM
overlandexpress
Feb 11, 2010 10:00 PM
cwalsh540
Aug 12, 2008 08:46 PM
mailmandon
Sep 4, 2006 08:02 AM
