stock spring heigth
Old Nov 21, 2019 | 12:37 PM
somethingclever's Avatar
somethingclever
Green Bean those are factory overload blocks. Very common. They are actually tapered about 1/8” F/R.
Old Nov 22, 2019 | 06:15 AM
badbootbob's Avatar
badbootbob
Originally Posted by 73GreenBean
I'll measure her this afternoon!
sharp truck, nice lines I couldn't seem to get the gap between the hood and fender to equal the doors and fender. Hopefully the bodyshop I take it to can fix my inexperienced assembly.
Old Nov 22, 2019 | 08:40 AM
73GreenBean's Avatar
73GreenBean
I wasn’t able to get the numbers yesterday badbootbob but this afternoon I’ll crawl under there and get them for you. Take a picture of your gap on your hood and fender and I’ll see what I can do to help you out. If the back is too high you’ll have to loosen the 3 bolts on the inner fender where the horn sits on the firewall and move it down there. If the front is too high, you’ll need to adjust your hood latch up to compensate. If the hood and cowl are level you’ll need to adjust the rear of the fender next to the door up inside the fender there is an L shaped bracket that it will slide on. I’d start there but some pictures would help if you want to save money at the body shop. Their rates can be over 100/hour and they may spend an hour or two on your gaps...
Old Nov 23, 2019 | 06:50 AM
badbootbob's Avatar
badbootbob
thanks for the info do I need to put my pics on the computer or can I do this from my smart phone?
Old Nov 23, 2019 | 06:54 AM
73GreenBean
You can go to the website on your phone and do it or you can download the Garage Talk app from your App Store and do it that way( the way I do it) personally I like the app better because it's simple and you don't have a bunch of other confusing things on the side if your screen to look at
Old Nov 26, 2019 | 08:36 AM
73GreenBean
The axle to bottom of frame measurement is about 8 3/4" now with the bed on.
Old Jan 10, 2020 | 09:50 PM
badbootbob's Avatar
badbootbob
sorry I didn't get back to you sooner,I had to get back to both my job and my business. I'll check my height tomorrow morning.
Old Jan 10, 2020 | 09:59 PM
badbootbob's Avatar
badbootbob
Here's what I did.
Old Jan 10, 2020 | 10:01 PM
badbootbob's Avatar
badbootbob
Ok how do I add multiple pics. It's going to take hours to do this one at a time!
Under Pressure
Jan 13, 2018 06:37 PM
LittleBlue79
Mar 26, 2017 07:00 AM
GBuckert
13
Apr 17, 2011 11:00 PM
show101
Jun 3, 2007 10:22 AM
loghomeman
Jul 18, 2005 12:18 AM
