85 Van wont run
Old Oct 8, 2003 | 03:36 AM
Pavel's Avatar
Pavel
85 Van wont run
My little brother isn't to mechanically inclined and he had to take the battery out for some reason but when he put it back on he didn't put postive with postive and negative with negative.... He fried a fuseable link.
I fixed the problem when I got back home and corrected his mistake. But what struck me as weird is that the voltmeter gauge was not in its normal postion. It would swing towards charge anythime it was revved. A week later the battery died and needed a new one.
It was running fine but still the voltmeter was indicating overcharging. about 2 days after buying the new battery the van just died while on the highway. no sputter no warning like I just turned the key back to turn it off.
It wont turn over at all with the key. I have to apply direct current to the stater solenoid inorder for it to kick over. And thats all it will do, it wont start at all.
I also have to have the battery charger charging the battery at the same time inorder for it to turn over. as soon as I take the charger off it won't do anything.
I've checked and theres no current to the ignition switch and coil. I have an 2 extra duraspark box's and have switched between them and nothing still.
HELP!
Old Oct 8, 2003 | 07:56 AM
locknkey's Avatar
locknkey
You don't say what type of engine is in this model....EFI or carb?
Old Oct 8, 2003 | 02:49 PM
Pavel's Avatar
Pavel
sorry I was typing this late last night and was tired.
Its a 351w HO with a carb.
Old Oct 8, 2003 | 09:16 PM
locknkey's Avatar
locknkey
Sounds like an in-line fuse some place thats pop....
Old Oct 9, 2003 | 02:56 AM
Pavel's Avatar
Pavel
Any idea where? The fusable link thats between the battery and the silenoid is fixed but where else could there be a possible burnt link.
Old Oct 9, 2003 | 01:44 PM
locknkey's Avatar
locknkey
could be to the main wiring to the ignition, you'll have to look carefully...but its there, it will be either soft at that spot or burned into from the inside the little rubber shell. if you take a safety pin and stick them beween each fuseable link and use a multimeter on OHMS with all battery connections disable, you'll find it...check for ohms in the link, if you get none, it will be part of your problem, depends on how far the short got...also check inside your fusebox for any blown fuses.
Old Oct 9, 2003 | 03:26 PM
Pavel's Avatar
Pavel
Thanks!
