Sponsored by: Real Truck
Problems. No crank.
Old Sep 15, 2019 | 09:13 AM
Danwall79's Avatar
Danwall79
Problems. No crank.
OK. Heres the issue. I had an HPOP leak. I fixed it myself. Was running OK. But unfortunately I bust a line off (must of stripped the thread). Van cut out. Tried to restart. It cranked over. Then just stopped cranking.It hasn't cranked since. Im just getting a single click. Somewhere around the front fender on the passenger side. Theres no ready to start light and the ABS light comes on immediately as I go to turn the key. The ABS light comes on before I go crank. As if the ABS light is stopping it cranking. I pulled the ABS relay out but still not cranking. So any ideas?
Old Sep 15, 2019 | 10:13 AM
alloro's Avatar
alloro
Identify the vehicle.
How old is the starter?
Old Sep 15, 2019 | 10:00 PM
99f350sd's Avatar
99f350sd
Wire or starter or solenoid. Not real hard..
rodster150
1997 - 2003 F150
Apr 16, 2013 12:04 PM
Country4.2
1997 - 2003 F150
Jun 12, 2006 09:54 AM
bogking
May 16, 2005 05:32 AM
