Door power window electric issues
Old Sep 14, 2019 | 06:38 PM
Retired 2014's Avatar
Retired 2014
Has anyone experienced any issues with power windows? My passenger window all of a sudden when commanded to close will go full closed, the go full open in the same cycle without retouching the button on either door.
Old Sep 14, 2019 | 07:10 PM
KJ Smith's Avatar
KJ Smith
There is a safety built into it.
Make sure there is nothing stuck at the top.
If clear there, I think there are reset instructions in your manual.
Old Sep 14, 2019 | 08:17 PM
Retired 2014
Thanks for your advice. Went out to the truck, checked for any obstruction. Found none. Pulled out the owners manual, p 94. Followed the instructions. Nothing seemed to work. Had to bump the window up in several increments til it sealed. Had to repeat the process several times before I got it just right. Plan to bring it and have factory technician check it out. Due for an oil change soon anyway. Again, thanks for your comments.
Old Sep 16, 2019 | 05:26 PM
Retired 2014
Any possibilities that the battery could influence this operation?
Old Sep 16, 2019 | 08:43 PM
JKBrad's Avatar
JKBrad
I’ve found over the years that when a battery in a Ford becomes weak, all sorts of strange things happen. The first sign was that the gauges would act strangely. I don’t know how this carries over to the newer CANbus systems.
As far as window operation, the first thing I check is the switch itself.
Old Sep 16, 2019 | 08:54 PM
Retired 2014
I am currently traveling, but will check it out a little more thoroughly when I am home this weekend.
Beeler
Nov 13, 2016 01:15 PM
wiskyseria
Nov 8, 2004 11:01 AM
ajstephan
Jul 20, 2004 03:17 AM
iflooru
Dec 5, 2002 06:03 AM
zeb
Aerostar
Jun 14, 2000 10:56 AM
