I got the same thing going on. Contribution cyclinder 8. Mine started hard. And idled weird like it was missing and had a knock when under load a little bit. Had shop put all 8 injectors in and it did same thing. Doesn't always throw the code but runs like ****. Took cab off, pulled valve cover, turbo and driver side head and everything looks great. Cams good heads good. Don't no what 2 do next
try to reset high preasure fuel system and also reset injectors
This sounds just like mine. I've chased this for 4 years and 40k+ miles. Replaced the injectotvtwice with little to no change. Mine is cyl 4. Occasionally throws a code (every 4-6 months-). I reset it and it stays off for several months but symptoms remain consistant. I get a knock/rattle under load between 1500 and 2000 rpm. More pronounced in cold weather (under 45 *F). With rough idle it the colder temps until engine is warmed up.
Otherwise, it runs and idles well. I've taken the position that if it hasn't blown up in over 40k miles of use, this probably isn't fatal. Just did an 8 hour round trip this weekend with no issues.
I'd love to know if someone ever does figure their's out.
do a high pressure fuel system reset and Injectors
What does light diesel knocking sound like? I think I have it but I've been told normal on several instances. I've been around other similar year PSD and they didn't sound like mine so I've been wondering all along what the diesel knock sounds like. Googling just tells me nothing
