Would appreciate help with antenna cable
I've always stood on my tires to clean the windshield. I slipped off the front passenger side tire and caught my right arm on the antenna and bent it. I tried to ease it back and fatigued the metal and broke the bracket. I have new cable and mast, but the mount base is one piece with the cable. I have the cable detached front the sound system and have the cowl cover up, but can't seem to see the grommet to pull the wire out. It looks like the entry point is either behind the fender or down low on the fire wall. I can't find it and don't want to start tearing things up. Boy is it packed in and under the dash! Do I have to remove the wheel well liner? Thanks. I've scoured this site and the web and apparently I am the only person to ever break the antenna base.
on
Thanks everyone for the help. Really appreciate all the suggestions. mwheue your link to the F-150 site really helped a lot, but I went NStorm's way. I tried pulling the wheel liner back and reach up to pull the grommet as I was not looking forward to pulling the liner. Couldn't reach. Took NStorm's brilliant advice....easy peesy back in biz! Just pull the cowl cover up, pull the broken end up, undo the metal crimp and pull. Pops right out. Unscrew #3 7mm bolts and remove broken piece. From new cable pack, undo the metal crimp from the new base and fit coax into it. It can only go in one way very easy. Crimp it. It's a 90 degree retainer. I had a small amount of rust on the retainer that needs to be crimped so I put some dielectric on it. Bolts back in x 3. Put cowl cover back. It clips in place with palm pressure. Reconnected existing orange coax to audio. FIXED! I am leaving the glove box hanging one more day as I'm gonna change the cabin filter while it's apart. Thanks so much everyone. The help here has always been great so I became a contributing member today.
part number w/ old broken base
Stick cable end to new base
Broken base with retainer
The following users liked this post:
on
