what engine do i have
Old Apr 8, 2001 | 10:46 AM
cpnhgnjnky's Avatar
cpnhgnjnky
i just purchased a 95 f150 5.8L eddie bauer 4x4 ext cab. i have found that the engine that i have has the engine code H, my manual does not have a listing for that block. is it a clevland/windsor? thanks for your help.
Old Apr 8, 2001 | 11:29 AM
MARC's Avatar
MARC
You have the Windsor motor, all of the trucks have the windsor motor. clevelands were in the car from the late 60's to mid late 70's (torino, galaxie, some mustangs, which also used windsors in the mustangs, etc)
Old Apr 8, 2001 | 04:48 PM
Pastmaster's Avatar
Pastmaster
All of the trucks since 1983 have the winsor motor.
BTW, your 95 351 has 210hp and 325ft/lbs of torque.
Old Apr 9, 2001 | 12:35 PM
cpnhgnjnky's Avatar
cpnhgnjnky
i really do appreciate the response. i guess the other question i have is in 95 what was the difference between the 95 R code block and the 95 1/2 H code block. i'm stationed in germany and finding out any info is hard. its all bmw or merc crap over here. once again thank-you.
cpnhgnjnky
Old Apr 9, 2001 | 07:46 PM
jamden's Avatar
jamden
The 95 H code was the 351 ci (5.8 liter) in the Bronco, F 150, 250 and 350. I don't know about any 95 1/2 H code, the 96 was the same as 95. The 95 R code was the 351 ci in the F150 Lightning. There was no 96 R code (no 96 Lightning?). The 95 H code made 210 hp @ 3600 rpm and 325 ft/lbs @ 2800 rpm. The 95 R code made 240 hp @ 4200 rpm and 340 ft/lbs @ 3200 rpm. I don't know what all difference the R code had over the H code to make the bigger power but the exhaust valves were larger and the cam elevations were different. As per your question, the blocks were (are) identical.
1992 F150 Supercab SB 4x4 302 AOD 3.55 31x10.5 All Terrain on Ford 15x8 Ralleys
Old Apr 9, 2001 | 08:57 PM
mike dalton's Avatar
mike dalton
