4r100 TC seating help
Old Sep 7, 2019 | 03:51 PM
cesspool's Avatar
cesspool
i got A new TC for my excursion, 4wd, 126k 7.3. I got an eagle 6 stud form racer X. and a billet input shaft and a new pump seal. I cant get the TC to seat. he says with a striaght edge across the bell housing, it should sit 1/8" to 1/4" below. I have been pushing and spinning this thing for 2 hours and I cant get iot to seat. the old one is no prob. and now I cant get my input shaft out either...
its the weekend, so they don't answer the phone... and suggestions?
Old Sep 7, 2019 | 06:14 PM
cesspool's Avatar
cesspool
Old Sep 7, 2019 | 06:18 PM
cesspool's Avatar
cesspool
so the 1st 2 pictures are the hub shoulder differences. the old one had more of a shoulder.
new TC is blue
more concerning to me tho, is i let a long screwdriver inside the old hub, laid a pair of pliers over the hub and grabbed it. moved to the new hub and when I put it inside, you can see it isn't as deep. its 3/8" off, which would put me ~1/4" below the bell housing if they were the same. any chance the input shaft is bottoming out thus not allowing the new one to seat all the way. I feel the clunk and it drop but its not as deep as the old one. I looked online but I cant find any info as to how deep the hole should be.....
Old Sep 8, 2019 | 11:38 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I'm not much help but the Seal surface on that Blue one don't look so good to me... but maybe it's just the pictures.
IMHO I would be concerned with that depth too.
Old Sep 8, 2019 | 11:57 AM
ajbrown208's Avatar
ajbrown208
Take the input shaft out of the tranny. Just be easy with it. It will come out again. Then use the input shaft in place of the screwdriver. Check the difference if any with the input shaft. If no difference, try pushing the torque converter on with out the input shaft. QUESTION???. Have you been in the transmission at all???
Old Sep 8, 2019 | 11:58 AM
ajbrown208's Avatar
ajbrown208
Have you had the pump out and apart??
Old Sep 8, 2019 | 03:14 PM
cesspool's Avatar
cesspool
I have not been in the transmission at all yet. I can't get the input shaft out now.... Racer emailed me the below: is the pump a simple swap?
Based on the photos, it looks like the old converter had excessive wear and end play, possibly it’s come apart inside. That would wear the pump and hammer it, possibly explaining the ding in the front of the pump shaft. It that’s a gouge in the hub, it’s been hammering against the pump inside, the photos look like it’s been hammering on the hub end too, the score marks are probably from excess end play or pump wear. If the converter is completely drained and doesn’t have enough ATF residue left inside that would provide a cushion, try shaking it and see if it rattles or you feel the internals move back and forth while shaking it. Has the transmission pan been removed and checked for metal particles?
We’ve covered as much as possible here, you’ll have to talk to the tech dept on Monday if possible, or have a tranny shop inspect it if possible.
Old Sep 8, 2019 | 06:26 PM
ajbrown208's Avatar
ajbrown208
OK. The pictures you have. Is the some type of lube on the new convertor and the grooves are just a reflection of the outside of the convertor? I notice that (groves) changed locations in the different pictures of the same convertor. If you can not get the input shaft out, your going to have to go in that tranny and get it. It slides in and out Easily. And only installs one direction. The pump is a fairly swap. 1st. Pull the pan cover off the bottom. 2nd inspect the magnet in the bottom of the pan. DO NOT< DO NOT< DO NOT Forget to reinstall the magnet. 3rd. remove the filter simply pulls straight out. Now you can remover the pump. Checking out "Another 4R100 Build" in this forum.. I'm thinking either the pump or the female splines has your input shaft arrested.
Old Sep 8, 2019 | 08:21 PM
cesspool's Avatar
cesspool
yes there is assembly lube of some sort on the new TC. Ill talk to him tomorrow. I pulled the pan, few little debris but I think they fell of the outside into the pan when I removed it to be honest. I had a trip 1600 mile trip to Canada planned in T minus 8 days.... this was supposed to be a 2 day project that is now more of course. I have pretty much no tran exp other than changing the filter in the pan and installing a valve body. I do have an external filter which may have helped me, idk if its just adding the pump swap, hopefully i can till make vacay
Old Sep 8, 2019 | 10:04 PM
ajbrown208's Avatar
ajbrown208
I just re read this. Especially the part about the new billet input shaft and pump seal. Were the input shafts identical? And you think one problem is the depth of the new convertor? But I still cant get through my mind why the input shaft is stuck. You might try turning the transmission upside down, putting a block of wood under the bell housing where it meets the floor, and have someone pull on the input shaft while to tap the housing on the floor/wood. Even rocking it from side to side If you have the pan off, it may be in this position now. If the new pump seal is a front seal, you need to install a new bushing too. Don't worry about not having any experience in the tranny. Very few of us do. I think you can make your trip. Keep us posted on what the tech has to say. Let them know that there are a lot of eyes watching. (Potential Customers)
Old Sep 9, 2019 | 10:41 AM
cesspool's Avatar
cesspool
i got the shaft out. I think just all the pushing and clunking over and over trying to seat it may have just set it in a bit, I've been talking to Racer X - very helpful and nice. great guy! I can get the new TC to seat with out the input shaft, but its a quarter inch from being able to seat with either shaft in.... so Ill see what he says when we talk again
Old Sep 9, 2019 | 10:48 AM
ajbrown208's Avatar
ajbrown208
Good to know. It's not on your end. Something is OFS with the converter. The input shaft goes to the same depth as the screwdriver though. Curious. What's the reason for changing the torque converter out? We having some bad symptoms on something
Old Sep 9, 2019 | 12:03 PM
cesspool's Avatar
cesspool
there was some shudder going on. im trying to swap it before it takes the trans with it lol
Old Sep 9, 2019 | 02:21 PM
cesspool's Avatar
cesspool
so I removed the input shaft and the new TC seated right. I measured and the new and old shaft are the same length. but i put them in the new TC and the old one sticks n the TC an 1/8" more and then I did the same in the Trans and the new one sticks out 1/16" more. so thats 3/16" of an inch which is exactly how much I'm off. so I put the old shaft in the trans and worked it and I got the new TC to seat 1/8" below a straight edge across the face of the bell housing. so maybe the whole issue all along was the input shaft. Ill wait to talk to racer X, but I think Ill just go back with my old input shaft
Old Sep 9, 2019 | 06:10 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Ahh so their shaft may not be machined right or maybe it has burrs or is a little too large in Diameter(not machined right)
