check engine light
Old Oct 7, 2003 | 06:27 PM
vics97xlt's Avatar
vics97xlt
Angry check engine light
check engine light came on the other day. engine was missing and almost stalled then cleared itself. soon after that the light came on. went one day with light on.got out of work today and no more light. dsoes anybody know what might have happened and should i be worried about it. also a couple of days before this happened i stopped for coffee in the morning and when i came out to start it , it would not start, just crank. after third try it started and has not done it since. i have had two fuel pumps put in. one @42000 and the other at 82000. i now have 125000 on the odometer and still going strong. 4.6 ltr
Old Oct 8, 2003 | 09:22 AM
buzzard's Avatar
buzzard
It could be many things, try hooking up a OBDII code reader to the PCM. This should give you a code that you can then look up to pinpoint the problem. Autozone will do it for free.
