cranks but doesn't start
Old Sep 4, 2019 | 10:35 PM
bradleyheathhays's Avatar
bradleyheathhays
So I got this '96 Jeep Cherokee XJ that cranks but doesn't start. It's got around 180k on her but I keep everything in good shape. Batt seemed strong.
I used to drive it everyday but this past year I've driven it only about twice a week. It's been just slightly slower to start in the last couple of months, but just barely slower. Was guessing it had something to do with aging plugs or something.
Drove it yesterday and everything was normal like always, sat overnight and today it cranked but didn't catch.
Any ideas on where to start?
Old Sep 4, 2019 | 10:47 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Crankshaft Position Sensor
Old Sep 5, 2019 | 07:16 AM
BassFantasizer's Avatar
BassFantasizer
If it's gradually gotten slower to start, you may have a fuel pressure issue. The low-hanging fruit is the fuel filter, but I have no idea if that Jeep has one or where it would be.
Old Sep 5, 2019 | 09:12 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Well, without some Basic trouble shooting.... ie do you have fuel and spark, it's a Crapshoot...the Crank sensor is a common failure item I've probably replaced more of these than anything else on those old jeeps.
Old Sep 6, 2019 | 04:44 PM
bradleyheathhays
So far I've been able to run a couple tests..
Hooked up a fuel pressure gauge and first key turn got it up to only 20psi. Second turn got it up to 45. And third and subsequent turns got it up to 48. It only fell to 43 after 2 minutes so I think that means the fuel pressure is good.
Hooked up a spark tester between a plug and wire and it didn't light at all when cranked so I'm guessing I've got a spark problem. I'll start by doing a tune up with new rotor, cap, wires and plugs then see what happens. After that it I'll go after the crank position sensor and spark sensor.
Old Sep 6, 2019 | 05:33 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
the crank sensor is the Spark Trigger if you will
when it fails you get no spark.
EDIT: I don't know if this is any help to you ..... https://troubleshootmyvehicle.com/je...crank-sensor-1
Old Sep 13, 2019 | 12:13 AM
bradleyheathhays
Cool thanks for the link
R33df250
New Member Introductions
Aug 2, 2016 09:20 AM
