I need a bolt 31528-S How do I find the size and thread info?
Originally Posted by RTT
44 Views Not one reply..........
Where did you find this 'hardware' part number? You cannot look up hardware parts by application in the parts catalog...unless you know where the parts were used.
You cannot expect people to respond to this impossible question within two hours, especially on a 3 day weekend. Today is Labor Day.
ON SAME PAGE I GOOGLED 20346-S AND FOUND HEX HEAD BOLT 5/16-18X3/4" . I NEED 2 OF 31528-S FOR COLUMN BRACKET IN CAB THAT I BELIEVE ATTACHES TO BOTTOM TWO HOLES OF UNDER-HOOD BRACKET THAT HOLD REVERSE SWITCH VIA A CLAMP!
ON SAME PAGE I GOOGLED 20346-S AND FOUND HEX HEAD BOLT 5/16-18X3/4" . I NEED 2 OF 31528-S FOR COLUMN BRACKET IN CAB THAT I BELIEVE ATTACHES TO BOTTOM TO HOLES OF UNDER-HOOD BRACKET THAT HOLD REVERSE SWITCH VIA A CLAMP!
You have to look up standard parts with the parts they were used with, in this case 3B633 & 3513. I also looked under 3668 but there's no listing.
So I looked in the 1948/56, 1957/63 and 1973/79 truck parts catalogs, 1949/59, 1960/64, 1965/72 and 1973/79 Ford car parts catalogs...no listing there either.
So, the only thing one can do is look up the bolt in a Standard Parts (hardware) Catalog. I have one, but it's dated 2/2000. This bolt was obsoleted by this time, so there no listing for it.
~~~Thank-you all~~~ I am embarrassed to say I probably have bolt but can not find it or hole is so rusted I am having trouble getting it back in!!! I need to label my parts and sort them in smaller groups!!!
Thank-U GaryKip I will try the site u suggested~~~
*** Just 2 clarify*** Bracket 3668 in illustration is not like the one I have. Mine is 5 hole. The one shown maybe for power steering model??? I have I think 5 bolts 20346-S. I have known I need a screw gauge but spent money in other places.
Thanks-everyone again.
I need Garage Squad.......lol.......
Mr. Num Dummy, Will u share how you found the missing 8 suffix number?
Also , I apologize for my spuratic activity here on FTE. I suffer from self diagnosed- ADD, Hypochondria among my other aliments...etc...etc, and Lingering late 70's fog .....
