71 camper special
Old Sep 2, 2019 | 02:58 PM
reddogg94602's Avatar
reddogg94602
71 camper special
Hi there.
Just wondering if a 71 camper special could handle a 7135 g.v.w.r fifth wheel?
Old Sep 2, 2019 | 03:45 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
,...........................No ! ........................Not safely. Or MAYBE if new. It'll pull it but can it STOP it ???
Old Sep 2, 2019 | 05:20 PM
'65Ford's Avatar
'65Ford
If it has solid frame, good suspension, good brakes, good tires, solid driveline, is at least an F250 and has an engine making over 350 lb ft of torque then yes. Won't likely find a tow rating for it though. And you'll have to wire up a proper trailer harness including brake controller.
That's a fairly light fiver.
Old Sep 2, 2019 | 07:32 PM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
Originally Posted by reddogg94602
Hi there.
I think the Camper Special was set up for slide ins.
Old Sep 2, 2019 | 10:11 PM
reddogg94602
Spec's for the camper special
Stock 360 rebuilt brakes and carburetor.
F-250
Old Sep 2, 2019 | 10:31 PM
'65Ford's Avatar
'65Ford
F-250
Add to that everything else from bumper to bumper...brake hoses, master cylinder, king pins, I-beam and radius arm bushings, front and rear springs, tranny and engine rebuilt, etc ...everything in top shape.
Will also want a 4.10 rear axle ratio.
I pulled our 5ton fiver 10k miles of interstate with my '65 F250 after it was completely rebuilt and added a stock 390. Now we mostly use a 2002 diesel.
Old Sep 3, 2019 | 09:12 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
It'll be slow up the hills, but get all the safety and reliability stuff up to par and it will do it.
Paul Gavin
Feb 6, 2023 04:42 PM
thenap1
Feb 4, 2011 04:33 PM
Hellbore
18
Jun 9, 2006 10:01 PM
