Suspension; help me understand
Old Sep 2, 2019 | 01:00 PM
RyanMac119's Avatar
RyanMac119
We have WD, no worries
Old Sep 2, 2019 | 06:22 PM
Jakerichards1's Avatar
Jakerichards1
Commonly overlooked slop
Take a very close look at the slip joint on steering shaft. Very common to have a little play there.
A 1/16” play Is like an 1” when out on a 13” wheel.
I shimmed mine. Others buy a 200$ oem shaft. Others do 600$ custom u joint style.
Old Sep 2, 2019 | 07:14 PM
pirate4x4_camo's Avatar
pirate4x4_camo
yup, buts its just one of the over looked points that induce steering slop. best to do a complete inspection from wheel bearings to steering wheel. a little here, a little there , they add up and before you know it your ex wanders like a drunken sailor
Old Sep 5, 2019 | 07:52 AM
96firephoenix's Avatar
96firephoenix
what did you use to shim it? cheap feeler gauges?
Old Sep 5, 2019 | 06:59 PM
Jakerichards1
Shim
I cut off piece of stainless screw type hose clamp.
Bent it to match the curve of the star then bent the stick out to about 90’ and tapped it in with a small hammer. Then took the rest of the stick out and folded it back up the upper part of the shaft. Secured with another hose clamp.
Sprayed it all with fluid film so it doesn’t rust. Rubber donut does not fit up over it now.
Took up all slop. not too tight. I can still remove the shaft from gear box and push it up and down when I swapped gear box last year. Still functions as oem safety device.
Old Sep 6, 2019 | 04:02 PM
pirate4x4_camo
alternatively you could install a new one for $100 bucks
https://www.tascaparts.com/auto-part...ing-wheel-scat
Old Sep 8, 2019 | 05:36 PM
Lance Helmert's Avatar
Lance Helmert
LARES 11602 Info
Power Gear
$334.79$0.00$334.79
Add to Cart
BBB / VISION-OE N5010119 Info
4WD; Power steering (Only 4 Remaining)
$386.99$0.00$386.99
New steering gears can be bought, instead of getting a reman.
afiggis
Jul 21, 2022 04:39 AM
PremierPOWER
Dec 8, 2018 04:01 PM
matt.gilbert
Jul 4, 2010 05:27 PM
floridadude
18
May 20, 2008 11:51 AM
nsaikia
Jul 15, 2005 02:18 PM
