No cruise control please help
Old Sep 1, 2019 | 02:27 AM
Dieseloholic1's Avatar
Dieseloholic1
I have an 85 f250 with a c6 trans cruise control worked going to town one day and on the way home later that day my cruise control would not thank you for your time and help
Old Sep 1, 2019 | 07:30 AM
tjc transport's Avatar
tjc transport
i ain't rite
it could be something as simple as a bad fuse.
or it could be a bad cable, or diaphragm in the cruise module to name a few things.
Old Sep 1, 2019 | 10:11 AM
Dieseloholic1
I see what fuse should I check I'm gonna start tracing this down today
Old Sep 1, 2019 | 11:20 AM
tjc transport
i ain't rite
fuse #6, 15 amp.
if that fuse is good, check the cable where it connects to the throttle cable at the injector pump. it may have become disconnected from the shaft.
another thought, check that the brake lights are not staying on with key on.
Old Sep 1, 2019 | 03:24 PM
Dieseloholic1
fuse #6, 15 amp.
Thank you for all your help I always thought the speed control was on the horn fuse I'll check the fuse l'll check that tonight if I get back in time I'll check that cable as well
Old Sep 1, 2019 | 05:27 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
check the dump valve on the brake too.
Old Sep 1, 2019 | 09:50 PM
Dieseloholic1
Will do thank you for the help
Old Sep 2, 2019 | 09:13 PM
Dieseloholic1
It wasn't the fuse sadly what would be the next most likely place to check
Old Sep 2, 2019 | 10:45 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
IF you have already checked the other things mentioned ... then check the Slip Rings and the Switch for correct operation.
check the connector on the Servo for corroded pins, check the Feed Back pot and the Vent Solenoid and the Vac Charge Solenoid, verify the speed sensor is working.
Did it ever Work ? IF so how well and did it fail while in use ?
Old Sep 2, 2019 | 10:54 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
this is for an 89 Merc but it shows the Guts of the servo for testing......
Old Sep 3, 2019 | 12:01 AM
Dieseloholic1
I'll check all that I can tomorrow and it use to work great no issues on the way into for me town is 55 miles each way on the way home that evening it wouldn't work and has been that way ever since
Old Sep 3, 2019 | 09:10 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
here are your Test procedures..... BE Careful when testing see the Caution Notes so you don't Fry the Amp...
Very Seldom have I seen the Amp Failed, many times it is the Connector on the Servo where the issue is (aside from vacuum lines or mechanical linkage)
Old Sep 3, 2019 | 09:39 AM
Dieseloholic1
Thank you when it comes to vacuum leaks what's the easiest way to test for them
Old Sep 3, 2019 | 10:34 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
with a Vacuum Gauge and a MityVac hand pump, the procedure is the last 2 statements of the PDF.... IF you have Good Brakes then your Vacuum is probably fine.
IF the dump valve on the brake pedal is leaking or IF that Vacuum Hose leaks then the Servo cannot build Vacuum to pull on the Throttle cable...... so you disconnect the Dump Line on the servo and apply Vacuum to it and watch for leak down.
there is only 2 Vacuum lines going to the Servo.... (Supply and Dump) ..... Ford Cruise Control - How it works
Old Sep 3, 2019 | 10:44 AM
Dieseloholic1
Where is dump valve non the brake pedal and what does it look like thank you for putting up with a noob like me
