2000 E350 AC Problem
Old Aug 31, 2019 | 09:34 PM
Pinzer's Avatar
Pinzer
On my E350 with V10, when accelerating with AC on, the cold air switches from the dash vents to the defroster vents. I've read that this is likely due to a vacuum-related problem, possibly a broken line or reservoir. Where can I get a vacuum line diagram for this year van?
Thanks.
Old Sep 1, 2019 | 04:13 AM
JWA's Avatar
JWA
Thanks.
See if there's anything here you can use: E-Series HVAC Vacuum System
Also another member here posted this video which offers another way to easily re-route the vacuum signal inside the cabin: Vac System Its a bit lengthy but interesting none the less.
HTH
Old Sep 2, 2019 | 09:07 PM
Pinzer's Avatar
Pinzer
Thanks for the link. Here are some links to some YouTube clips that show a work around to replacing the vacuum reservoir, which seems to be a likely culprit. Maybe these will help, too.
gwmontgomery
Jul 13, 2024 01:30 PM
phillips91
May 23, 2013 03:04 PM
robr0924
Nov 16, 2007 07:46 AM
currituckF150
May 21, 2007 03:51 PM
jponkey
1983 - 2012 Ranger & B-Series
Jul 23, 2003 06:00 PM
