more power
Old Oct 7, 2003 | 02:08 PM
88treadbrite_150_4spd's Avatar
Question more power
I HAVE 1988 F150 WITH A 4.9 EFI 4 SPEED AND I WANT TO PUT IN A CARBURATED 351W AND KEEP THE 4SPEED TRANNY WHAT DO I DO WITH THE EFI EQUIPMENT???????
Old Oct 7, 2003 | 02:28 PM
Txquadhunter24's Avatar
Txquadhunter24
if i was you I'd drop in a Newer model EFI 351W with MAF. That way you can go with much whiled cams then ya can with a EFI with MAP. Because your looking at a lot of work to Convert your truck back to the older DS systems needed to work Carb'd Motors. Once I went EFI i never looked back to the Carb's. Check in the 87 up Board there has been a few in there who has Made the Swap from 300 I 6's and 302's to the 351W. They love the power output of the 351W EFI. Yes you'll be able to keep your Tranny with a 351W upgrade. the 300 I6, 303 and 351W all use the same bellhousing boilt pattern. You'll just need a new flywheel
