2005 e-150 issues
Old Aug 29, 2019 | 02:38 PM
wtroger's Avatar
wtroger
2005 e-150 issues
Its an e-150 5.4 2v van (I know this is an f-150 forum but not much traffic in the van forum) you drive across a really wash board road or a rail crossing and the van will miss and barely run it sets the following codes p0405, and a p0452 it also will have a p0340. This was diagnoisted 2 years ago as a loss of 5v reference voltage. The pins coming out of pcm where shimmed and later the pins where replaced. This was good for a little better then a year. Drove over a rough rail crossing a week ago and it is back a vengeance. Worked on it some tightened some pins. Better for now. attached is a forscan log of last nights test trip there was one flutter. The FSM says dpfe voltage should not drop below .2 volts as you can see
there is a small amount of time when it was zero. and i believe it caused the fault spike and ftp faults. Any ideas on how to fix this or pinpoint the culprit.
Old Aug 29, 2019 | 03:31 PM
Rumble phish's Avatar
Rumble phish
Sounds like you need a new PCM my friend.
Old Aug 29, 2019 | 04:36 PM
wtroger's Avatar
wtroger
I have put a numbers matching PCM in it and no change in behavior.
Old Aug 29, 2019 | 04:52 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I may be oversimplifying, however: Take the doghouse off, start it up, shake wire bundles one by one. Might get lucky and find it.
Old Aug 29, 2019 | 05:24 PM
wtroger's Avatar
wtroger
Thats kinda where I am at now been chasing that circuit with a VOM
Old Sep 4, 2019 | 05:37 PM
pdqford's Avatar
pdqford
Which code shows up in the freeze frame data?
mosquito13
13
Oct 3, 2016 08:04 PM
eh.u.hoser
Jun 6, 2013 04:08 PM
Alta
May 28, 2012 11:14 AM
fordnut78
Oct 7, 2010 09:12 PM
Skandocious
26
Oct 23, 2007 10:34 PM
