tires and bolt patern on 92 explorer
explorer uses a 5x4.5 wheel bolt pattern so you would have to use adaptors to fit whatever wheels you are trying to fit. keep in mind in some states adaptors are illegal for road use, and thay will change the backspacing of the wheel, and therefore make fitment harder to judge for your tires. in my experience, a stock 92 explorer fitted with 31 inch tires will rub the radius arms on sharp to hard turns with a stock wheel... don't know about adapted wheels
