Axle codes
Old Aug 27, 2019 | 04:05 PM
dynarider33's Avatar
dynarider33
Axle codes
I have searched with no specific year models results, (2017+). Does anyone have the axle codes for these years?
Old Aug 27, 2019 | 04:07 PM
ToMang07's Avatar
ToMang07
I know "4M" is 4.30 gears
Old Aug 27, 2019 | 04:54 PM
UGA33's Avatar
UGA33
These are the 2020 codes. Betting they are the same.
Old Aug 27, 2019 | 05:08 PM
dynarider33
Prob the same without the “X” before the number. Thanks.
Old Aug 27, 2019 | 05:31 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Here's for the 2019's (so probably the same for '17-'19)
Old Aug 27, 2019 | 05:34 PM
dynarider33
👍🏼 Thanks.
Old Aug 27, 2019 | 05:41 PM
harmanrk's Avatar
harmanrk
Misleading charts are misleading..... Those are more code for the different rear end gears, rather than the axles. They in fact give no indication of Sterling vs Dana.
Old Aug 27, 2019 | 05:44 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The charts are not misleading. They display exactly what they are supposed to. I think the OP is wanting to know the gear ratios....not what axle us under the truck (which can be identified by a quick glance under the truck and the diff cover)
Old Aug 27, 2019 | 06:20 PM
dynarider33
Yes I was looking for the axle codes on the door jamb sticker. Looking for a 17-19 F350 DRW but want to make sure it doesn’t have the optional 4.10 gear.
Old Aug 27, 2019 | 07:42 PM
harmanrk's Avatar
harmanrk
Isn't the ratio also quickly, by the same glance at the tag on on the axle? I honestly don't know if Ford gave us the metal tag attached to the diff cover, but I know it is commonplace.
Old Aug 27, 2019 | 08:22 PM
UGA33's Avatar
UGA33
There is a metal tag on the axle.
Old Aug 28, 2019 | 05:27 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yes, but you have to crawl under the truck to read it. Not the most fun when the pavement is wet, you're in nice clothes, are too old or fat, or have a dozen + trucks to look at. Much easier to open the door and read the code on the sticker
I have this one saved on my phone for the '90's trucks. Tags are usually missing, damaged, or rusted. Door sticker is almost always there though!
Old Aug 28, 2019 | 11:48 AM
wrvond's Avatar
wrvond
Curious about why you would want a DRW with taller gears.
Dunk
Jul 11, 2004 01:18 PM
killerklown
1978 - 1996 Big Bronco
May 30, 2004 12:27 AM
Dustin_86
Dec 12, 2003 05:34 PM
460429_freak
Jan 30, 2003 06:08 PM
Franklin2
Feb 12, 2002 12:30 PM
