Coolant Bypass Fitting
Old Aug 25, 2019 | 08:54 PM
crazy96863's Avatar
crazy96863
I need to install a fitting in the coolant bypass on my new Edelbrock Performer intake. What I am thinking of doing is tapping threads (3/8-18 NPT) into the manifold and installing a brass barbed fitting. I figure this will make for easy replacement of the fitting in the future should the need arise. The alternative is to hammer in a brass pipe to serve as a replacement to the factory steel fitting or purchase the fitting for about $25 and hammering it in; I like brass. I may have to cut the fitting down one or two barbs for clearance which is not a big deal.
To be honest I am a bit leery about cutting threads into a $400 manifold but no more than hammering something into it. I thought I would check myself by asking for feedback. Any reason I shouldn’t proceed?
Old Aug 25, 2019 | 09:06 PM
Freightrain's Avatar
Freightrain
Threading it is a good thing. Just make sure you keep the tap straight, or the nipple will be aimed out of whack with back of water pump.
Just adjust how deep you tap the manifold to get the fitting to get down as low as possible, that way you don't have to shorten the barb section very much. Not so much you bottom the hex out!!!!
If things get really bad, you can always tap it 1/2" and use a reducer. Of course this will lengthen it more and cause issues. They may even make a 1/2" npt with proper barb?
Old Aug 25, 2019 | 11:56 PM
crazy96863's Avatar
crazy96863
I am pretty comfortable with cutting threads and being aluminum it’s forgiving. Being a brand new intake installed on a new engine I figure it’s worth the discussion as it can’t be undone. I just ordered the tap so I will do this as soon as it comes in.
Old Aug 26, 2019 | 09:26 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Pics or it didn't happen
Old Aug 26, 2019 | 10:44 AM
ford390gashog's Avatar
ford390gashog
I seem to remember this was tried years ago and it was ultimately figured out that because brass is cathodic the corrosion eats the threads out of the aluminum and causes leaks.
Old Aug 26, 2019 | 01:17 PM
crazy96863's Avatar
crazy96863
Would a stainless fitting have the same issue?
Old Aug 26, 2019 | 01:28 PM
ford390gashog
There is lots of aluminum nipples available that thread in to use instead of brass.
Old Aug 26, 2019 | 01:31 PM
crazy96863's Avatar
crazy96863
Or... use an aluminum fitting and alleviate all concerns.
Old Aug 26, 2019 | 02:43 PM
baddad457's Avatar
baddad457
Or just thread the hole and plug it with an allen plug and ditto for the matching port on the waterpump and use the heater bung and route that to the nipple on the outside of the waterpump. That way there's nothing to worry about in the future as far as leaks to be repaired. Lot easier to change an external hose instead of that pesky short hose between the pump and intake
Old Aug 27, 2019 | 01:22 AM
85e150's Avatar
85e150
Stainless and aluminum don't play well together.
Old Aug 31, 2019 | 02:46 PM
1browski's Avatar
1browski
Have you done this to your truck before? DO you have a pic of it? I just cant picture what youre talking about because my 70 f250 is not at my house at the moment.
Old Sep 1, 2019 | 08:33 AM
baddad457's Avatar
baddad457
Remove the bypass nipples from the intake and waterpump, then drill tap and plug the holes. Then use the heater hose fittings connected with a short hose to serve as the bypass hose. Never done it, but it's possible.
Old Sep 3, 2019 | 01:17 AM
Destroked 450's Avatar
Destroked 450
The factory aluminum intakes had a steel nipple, mine rusted out and we replaced it with one made of stainless around 20 years ago, no issues so far.
96_4wdr
Aerostar
13
May 3, 2020 06:58 AM
msalvetti
3.8 & 4.2L V6
Jun 5, 2016 09:12 AM
Ozark Pops
Modular V8 (4.6L, 5.4L)
Apr 19, 2009 10:53 AM
sbclemens
Apr 19, 2008 10:26 AM
copper_90680
Aerostar
Jun 28, 2005 12:10 PM
