Could it be 180* out? What was replaced besides the longblock (such as, ignition system parts or fuel delivery including carb)? The obvious question, do you smell gas?
Spark & fuel both ok. I replaced lots of things, so did the guy I got it from, so most parts are new. Maybe vacuum lines or the computer is screwing things up? I don't know. Thanks for your suggestions.
stepman
good to hear because as you can tell by my recent post count I have too much time to kill and this is where my energy is going. Quite frankly if someone thinks like me that tends to scare me. Just kidding, later
89f250
I know little about efi so my initial question of do you smell gas was intended more to a carbed motor when I saw 351m I first thought carbed. Sorry about that. Let us know if the tps was the problem. later
If TPS voltage is too high the ECM thinks you,re holding the throttle wide open. The ECM then decides you,ve flooded the engine somehow and it will not fire the injectors. This is called CLEAR FLOOD MODE. It will not begin to fire injectors until a certain rpm is reached which cannot be reached just by cranking. Using a volt meter see what the green wire from the TPS reads. It should be 1. volt or less and vary to about 4.5 volts at wide open throttle . Other two wires are 5.volts with key on, the other is ground.
