Rough until warm 7.3
Old Aug 20, 2019 | 06:15 AM
Rose88racing's Avatar
Rose88racing
I have a 2000 7.3 and it runs sluggish until it gets warm and then it's like a light switch smooths out and runs great. Any ideas what to look for?
Old Aug 20, 2019 | 06:49 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Injectors. ..
Old Aug 20, 2019 | 07:07 AM
Rose88racing
Need to pull and clean or service or replace?
Old Aug 20, 2019 | 07:48 AM
Colorado350's Avatar
Colorado350
Yeah, injectors. How many miles on them? I had the same thing going on, replaced them all.
Old Aug 20, 2019 | 08:39 AM
Rose88racing
285k never turned a bolt on truck...lol, Also have oil in valley of intake and looks to be running down backside of bellhousing. Truck has only had 1 oil leak since ive owned it and that was on drivers side oil pan area a round tube in the cold winter time would chunk out a little oil. Still need to fix that also
Old Aug 20, 2019 | 10:14 AM
z31freakify's Avatar
z31freakify
You can give your injectors a more life if you shim them. I used this kit and comes with everything to shim them including tools.
https://www.ebay.com/itm/94-03-7-3L-...ss!79821!US!-1
Old Aug 20, 2019 | 10:52 AM
F250_'s Avatar
F250_
308K mils on mine, and it's been doing the same thing for 60K-75K miles. I have the shim kit, but haven't found my ROUNDTUIT yet. I just let it idle until all the injectors are firing (only an extra 1-5 minutes for where I live (it's an ambient temperature thing).
Old Aug 21, 2019 | 11:21 AM
Brian Hanks's Avatar
Brian Hanks
Could be stiction and “possible” some of the oil additives could buy you some time. May be worth a shot. May not work but won’t hurt anything. Have definitely worked for some.
I’d look into those oil leaks though. check hpop lines. They are likely in need.
markkevin
Maryland Chapter
Aug 2, 2024 06:17 PM
Everlanders
Aug 13, 2018 02:30 PM
whitetmw
Jan 31, 2015 09:20 AM
