Vacuum leaks
Old Aug 18, 2019 | 11:30 AM
Albert Lovell's Avatar
Albert Lovell
Vacuum leaks
So I recently acquired a 93 f150 with 4.9 e4od. Truck has been a nightmare getting it to drive right. Finally got it road ready. Drove truck on highway for about 30 miles and half way through engine light would come on and off but not stay on. Light never comes on driving through the city. Got home and checked codes with engine off. Had no active codes but had code 172 in memory. Read it's saying o2 sensor lean. I was checking for vacuum leaks last night using a homemade smoke test. I had smoke coming from charcoal canister caps and egr valve. Is charcoal canister supposed to vent or does it need replaced?
Old Aug 19, 2019 | 02:35 PM
Albert Lovell
Any idea? Also o2 sensor says it's lean but at idle truck smells rich
Old Aug 19, 2019 | 03:47 PM
sandymane's Avatar
sandymane
If the O2 sensor is bad it is sending a lean condition to the computer. In turn the computer adds more fuel to compensate. Since your code is in memory that could cause your rich smell. I suggest you get the truck to operating temperature and do a KOER running test. Different codes can be in the different test. Sandy
Old Aug 19, 2019 | 10:02 PM
Albert Lovell
Ok so I did KOER test and only code I came up with is 172 twice which is same one that is stored in memory on KOEO test. Gonna replace o2 sensor and go from there I suppose. Only $20
Old Aug 19, 2019 | 10:13 PM
sandymane's Avatar
sandymane
Sounds like you probably need one even if it doesn't fix it. GL Sandy
Old Aug 19, 2019 | 10:32 PM
85e150's Avatar
85e150
I don't think you should be seeing test smoke out of an EGR or EVAP can. Check the area where you found smoke for an open line.
Old Aug 19, 2019 | 10:34 PM
85e150's Avatar
85e150
Is it missing, causing unburned fuel to give you that rich smell while in fact it's too lean to fire?
Old Aug 19, 2019 | 10:40 PM
Albert Lovell
Egr seems like it's leaking from the diaphragm. Charcoal canister seems like it's leaking out of the 2 caps on top of it.
It actually runs good. Doesn't seem like it's missing. Only problem is, it is getting like 10mpg
Old Aug 20, 2019 | 06:33 AM
minimalist's Avatar
minimalist
My charcoal canister blows smoke introduced with air pressure but holds a vacuum with a pump. These valves are supposed to release pressure so I think if you wouldn't see smoke they would be bad. At least that's what I came up with by myself. I might be wrong though.
Old Aug 20, 2019 | 07:25 AM
Albert Lovell
I think you may be right. I tried to spray carb cleaner where I believed it was leaking from but idle speed did not change. Also tried spraying the egr and no change as well.
Old Aug 20, 2019 | 04:41 PM
torq'ta 5 8's Avatar
torq'ta 5 8
where you find o2 sensor 20 bucks? JY?
Old Aug 20, 2019 | 05:46 PM
Albert Lovell
I didnt find one for $20. Was looking online at the time and first one that showed up was $20 but it was for a different vehicle. Ended up paying $40 at local parts store and only reason I got it for that cheap is because I have a business account with them
Old Aug 20, 2019 | 08:07 PM
F350 1990's Avatar
F350 1990
As for smoke leaking out of the canister, it has no moving parts, nothing to wear out so you probably just have cracks in the vapor purge connectors, lines...........you might also check the Canister Purge Regulator Valve.............I check this valve this way
Apply vacuum source to the side opposite the canister (5 in Hg) .........valve should not pass air if working, if it passes air it's bad
Apply 9V-14V DC to valve (I use a portable power supply) , valve should open once it gets the V, if not it's bad
Old Aug 20, 2019 | 09:31 PM
Albert Lovell
Where is this valve located? Is it on the passenger side firewall?
Old Aug 20, 2019 | 11:08 PM
Albert Lovell
An another note I replaced o2 sensor. Drove it and still coming up with code 172 and also 411 which I have never had. Tried unplugging iac and it didn't change anything. Read somewhere it was supposed to kill the engine or almost kill it
