Hello all, I’ve been working on replacing the radius arm on my 95 2WD for a few days now. I live in the Midwest so I’ve been enjoying copious amounts of rust. My real issue is the bolt that holds the radius arm to the I-beam; when trying to remove it I essentially mushroomed the top of it. I’m going to take a shot at cutting that bit off this weekend but was hoping just in case I manage to screw that up too that someone could point me in the direction of where to get a new bolt; or even the specs on it. Thanks!
Whoa, thanks for the replies. I ended up successfully(for now) cutting the damaged part off. Nut threaded on decent enough! Still haven’t completed the job; I’ve spent the last couple days I could working on it trying to clean up areas with rust. It’s great.
