Adjustable rockers
Old Oct 6, 2003 | 11:19 PM
Andysutt's Avatar
Andysutt
Adjustable rockers
Im looking for a set of adjustable rocker arms for my 390
What year trucks/cars had these so I can try and find them at a junkyard.
I really doubt I can find them, as I have only found a few vehicles in my part of the state w/ FE's in them
But I would really appreciate it if someone could tell me what years had them, or where to find a good set... new or used.
Thanks again
Old Oct 7, 2003 | 05:13 AM
Ratsmoker's Avatar
Ratsmoker
I would suggest buying new. The used will be hard to find at a junk yard and probably will be well past worn out. I bought mine from DSCmotorsport.com. For about $650 you can get the complete Erson roller rocker assemblies. Shaft and all ready to bolt on.
Old Oct 7, 2003 | 08:47 AM
Andysutt's Avatar
Andysutt
Hrm..
Thanks for the info Ratsmoker
I wasn't looking to spend that much money on them right now.
Considering I dont HAVE to have them w/ the cam Im running, and I still have a heavy manifold but good heads.
I thought they might be a bit cheaper. Maybe I'll just have to wait.
Thanks tho
Old Oct 7, 2003 | 09:22 AM
zsir's Avatar
zsir
actually you can get a stock set from DSC for a little over $200......or you can get a set with aluminum spacers and the correct push rods for like $290.... DSC has different combos available..... He just sold a set on ebay that were used but rebuilt for less than $150 I believe....
Check with DSC and keep an I on ebay cuz they pop up on ebay a lot.....Try and get a new set if you can because the rockers wear and you will also need to change your push rods too....
Old Oct 7, 2003 | 09:26 AM
Andysutt's Avatar
Andysutt
I seen a set on Ebay...
14 of them were drilled for some pin rollers or something
and the other 7 werent... they were like 30 bucks, but I dont know if they were worth it.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2435722089
