Well, it’s already necessary to go into electronics. And as far as I know, the truck’s security system does not allow them to be constantly hot
it's for battery protection.
It's probably easy enough to rewire the power to them but without a Schematic I do not advise arbitrarily whacking on the wire harness.
it would be better to install Auxiliary USB/Lighter box assembly.
That's what I would do, install a aftermarket unit.
In this case, this unit must interact with the energy that will produce heat for the cigarette lighter. And where will the block take it? From akkumulyator?
