If the parts guy at Klimesh says COTZ-8591-B replaced B2Q-8591-A .. then you're good to go.
Is the price right? How many have you found?
N.D., Point taken. Thanks again. In other news, using MixerMan's technique I moved the truck out for the car show in town. Had an appointment that afternoon and couldn’t attend. However, I know the onlookers enjoyed seeing a big truck. The F250 looks like a younger brother. I did notice a considerable drag as the truck came out of the pole barn. Thought maybe the brakes were stuck. It wasn’t until later that evening I noticed the furrows in the gravel. These trucks are heavy too! Thanks again.
do you happen to have any links to another water pump like this one? I have a 1952 ford f7 big job with the 279 engine and I'm needing a pump for it and I've had no luck finding anything for it. Thanks
Says 302/332 so I can only assume it will fit the 279
