Offroad & 4x4
Bronco 2 Build UP Complete
Old Oct 6, 2003 | 09:01 PM
kansastj's Avatar
kansastj
As you can tell from my user name I usually hang out on the Jeep forums. Today is different I have a free 1986 B2 at my disposal If I want it. Straight body and interior. Everything works except the tranny is trashed and it hasn’t been started in 4yrs, but has been garage kept. Here is what I would like to achieve:
Build strictly as a trail rig, but must be street legal.
Front solid axle swap. I have a d44 from a Waggoner in the garage right now. Prefer leafs to keep it simple.
Would like to keep the push button tranfercase. Don't care about keeping stock tanny or engine.
Run 33s w/ smallest amount of lift possible. I’m not afraid to cut sheet metal. I want lowest center of gravity to achieve this tire size.
Budget.
With this criteria in mind give all you ideas, experiences and ect.
Old Oct 6, 2003 | 10:12 PM
Dan Q's Avatar
Dan Q
Decent, but narrow, and short wheelbase. Not very articulate with IFS front end, but probably worse with straight axle. Solid body construction makes it very stiff, and strong. If you can widen it a touch somehow, and make the suspension travel, you may be on to something. Rancho makes a good articulate suspension, as does Superlift.
Good luck. Sounds like an overall fun project.
Dan Q
Old Oct 6, 2003 | 10:22 PM
JeremyH's Avatar
JeremyH
Re: Bronco 2 Build UP Complete
Hey.......me too!
Old Oct 7, 2003 | 11:03 AM
rebocardo's Avatar
rebocardo
The best and easiest way to do 33s, put a Dana 35 front, 8.8 rear in from a 1997 and under 4.0 Ranger. Almost a bolt up affair. Ditch the push button and go manual 1356 and manual hubs. 3 inch body lift, heavy springs front and back with fender trimming in back and you should clear 33s on 10 inch rims.
Get a manual from a 4.0 Ranger, grab the flywheel and starter while you are at it. It will bolt right up to the 2.9.
Straight axle and springs are more hassle then they are worth, even with a free axle, since a Dana 35 TTB from the Ranger will do swell with 33s off-road.
4.10s are hard to find in a Ranger, 3.73 is easy. Shop right and you could do it for well under $1000 not counting tires. The transmission will be the most expensive part out of a Ranger. You can find manuals for the BII at $200.
Old Oct 7, 2003 | 04:21 PM
JeremyH's Avatar
JeremyH
The 35 was not a front axle.
If you have a waggy 44, grabe the other and stick them both under there.
Old Oct 8, 2003 | 01:29 PM
77monster's Avatar
77monster
the 35 is a front axle found in the later rangers around 90 up and the 90 to 94 exploders have the d35 front axle and 8.8 rear its easer to find the exploder around my part so i would use them. the d 35 is a direct bolt in and the 8.8 depending on what the donor is is a direct bolt in. the explorer 8.8 just have to cut of the spring pads and relocate them to the top of the axle for the exploder is a spring under. while your at it get the rear leaves out of the exploder and relocate the spring pads to the top of the axle and it will give you an easy 2 in of lift. add a 2 in block and youve got 4 in of lift in the rear. the call up skyjacker or who ever and get the 4 in lift for the front and wala youve got a 4 in lifted trail ready rig that will run 33 with a little fender trimming and get you where you want to go. the stock d 28 and 7.5 wont hold the 33's and would probably break on the trailif you need anything else drop me a line always willing to help.
Old Oct 9, 2003 | 01:17 AM
BroncoRoadKill's Avatar
BroncoRoadKill
Personally, I would stick the D44 and 9inch from a fullsize, that would give you the width and you could probly fit 35s with a 3" body and fender triming.
Old Oct 9, 2003 | 02:58 AM
adamk1974's Avatar
adamk1974
Hello, I agree with 77 monster if you check out the axle spotters guide in the free off-road Adventures mag. you'll find that the ttb35 front end from another Ranger or Explorer is indeed an excellent choice. The TTB front end is Known for its long term durability and can comfortably handle a 33 inch tire due in part to its 297 spicer axle shaft joints the same joints found on dana 44's, and the 8.8 when equipt properly handles a 35" tire.
Go to your local Wrecking yard and get these parts you wont be sorry. I promise!!! make sure they are in good shape though not junk. GOOD LUCK!!! but you wont need it.
Old Oct 9, 2003 | 03:05 AM
adamk1974's Avatar
adamk1974
Oh and I almost forgot to clear these 33" tires you'll want @least 4" with cut-outs, but for serious offroad use a 6". I prefer Skyjacker. Great ride and bullet-proof!!!
Old Oct 9, 2003 | 03:39 PM
77monster's Avatar
77monster
thats why i was saying to use the explorer rear springs and 2 in blocks then get a 4 in lift from a repuable company then youll have a good 4 in lift all the way around get a set of bushwacker cut out fender flares and 33's here you come. you defently need 4 in of lift
Old Oct 9, 2003 | 05:43 PM
JeremyH's Avatar
JeremyH
Hummm.....I didnt know a 35TTB was used in the front. Is is a c-clip axle?
Old Oct 9, 2003 | 07:44 PM
77monster's Avatar
77monster
yes the d 35 ttb is used in the front of 89 up rangers and 91-up explorers and it is a direct bolt in for the d 28 ttb there is also rumor ive heard about useing the 35 innards and put them in the 28 houseing but im not sure
Old Oct 9, 2003 | 11:44 PM
77monster's Avatar
77monster
Dana 28 to Dana 35 swap - www.ford-trucks.com check this out its a simple write up about the swap from a d28 to a d35 but its basically all you need to know. Explorer8_8 and this is the rear 8.8 swap a little nicer write up this is what i sugest to do and as i said get the explorer rear leafs cause them alone will give you a 2 in lift in the rear hell if you want get 2 in coil spacers from a 2wd f150 leavleing kit thell bolt right in to the bronco II and lift it 2 in in front then trim the **** out of the fenders and stuff thoses 33's
Old Oct 9, 2003 | 11:53 PM
77monster's Avatar
77monster
forgot to say the explorer 8.8 is a better axle then the ranger cause all explorers came with 35 spline axle shaftes where the rangers mostly had 28 spline shafts Explorer8_8 here try the link again it dont seem to be working in the last post
Old Oct 10, 2003 | 07:37 PM
BroncoRoadKill
I think the rangers, B2s, and exploders, used the 8.8 equivilent, the 7.5.
And I beleive only the 1/2 ton 9" and 8.8 came with 31spline, the 35 spline is after market. I could be wrong tho.
