Trailer brake issue
Old Aug 10, 2019 | 11:32 AM
Don Schuler's Avatar
Don Schuler
Trailer brake issue
Been going to Ford about this for at least 6 mo finally the connector replace by telling them that I had trailer disconnect intermittent problem part #fu5z 1489a at no charge
Old Aug 10, 2019 | 01:00 PM
TeddyD's Avatar
TeddyD
Yup. They should of replaced the 7pin adapter. What they didn’t do was add dielectric grease to the new one. It’s not water tight and the corrosion will create the same problem again. You should pop out the adapter and add dielectric grease.
