GPR beat dowm
Old Aug 15, 2019 | 09:55 PM
  #31
knotreel's Avatar
knotreel
With out it, Before I installed the genuine GPR, I tested my the system with no GPR, using a meter connected to the ground wire that is switched by the the PCM. So, I got it working first then installed the new GPR. I was investigating the 5v ref by pulling all the sensors that used 5v and getting the open resistance between the 5v and ground wire ( measuring at the PCM plug) , then I measured each sensor by plugging them one at a time back end and seeing what resistance reading each had and I didn't find anything that jumed out as an excessive load on the 5v circuit. so there was no smoking gun. So I was surprised. The only thing that I can guess is during the unplugging and re plugging there was a sensor connector that was not getting good contact.
OldWoodsDiesel
37
Jan 13, 2020 11:53 PM
knotreel
Aug 10, 2019 02:45 PM
bsheets20061
Oct 4, 2014 10:44 AM
Joshglov
Feb 14, 2010 05:46 PM
79_250RangerLariat
Jun 9, 2009 07:34 PM
