Shifter rod bushing
Old Aug 9, 2019 | 03:20 PM
William's Avatar
William
Shifter rod bushing
Need a PN# for the plastic shift rod bushing that goes on the shift rod at the steering column. The rod is between the transmission and the steering column shifter arm. I guess if I knew the correct name for this bushing I could find one. Any help is appreciated.
Old Aug 9, 2019 | 03:52 PM
broktruk's Avatar
broktruk
These are usually at the parts store. They are in the “HELP” packages. Don’t know if they have them behind the counter but they are out front.
Old Aug 9, 2019 | 03:59 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by William
Need a PN# for the nylon shift rod bushing that goes on the shift rod (selector lever) at the steering column.
A/T or M/T? This is a "snap in" bushing with an internal shoulder, it can be a real b!tch to install.
Old Aug 10, 2019 | 08:26 AM
William's Avatar
William
This is for an automatic transmission. I have the column out and will install this "on the bench". Difficult to install ND and that is the primary reason I want to use a Ford part.
Thank You for your help.
Old Aug 10, 2019 | 02:34 PM
NumberDummy
EOSZ-7341-B (replaced C3AZ-7341-A, C7SZ-7341-D, C9TZ-7341-A, D4TZ-7341-A, D5AZ-7341-A and etc) .. A/T Shift Rod Nylon Bushing / Available from Ford - MSRP each: $5.87.
There's one on the selector lever on the column, another on the manual control lever on the side of the trans.
Dunno if any UT dealers have more than one, you could order it, but here are some other sources:
LARRY H. MILLER in SLC UT has 1 = 801-488-1700 extension 2708.
EARNHARDT FORD in Chandler AZ has 3 = 480-893-0000.
JIM CLICK FORD in Tucson AZ has 3 = 877-787-7149.
HOLMES TUTTLE FORD in Tucson AZ has 3 = 520-292-3723.
Old Aug 11, 2019 | 10:17 AM
beartracks's Avatar
beartracks
Couln't find the part on line at any of those dealers using EOSZ-7341-B
Old Aug 11, 2019 | 12:45 PM
NumberDummy
Originally Posted by beartracks
Couldn't find the part on line at any of those dealers using EOSZ-7341-B
I found them on PartsVoice.com, three of the sources I listed updated their inventory 8/8/2019, another updated 8/9/2019.
I doubt all were sold when I typed post #5. Plus...there are another 63 dealers listed on PV that have the parts, but I only listed the sources closest to the OP
Type the number like this: EOSZ7341B (no hyphens) and see what happens.
You could also call the sources and ask, when I list parts, this is what most people do.
And it's available from Ford: MSRP each: $5.87
Old Aug 11, 2019 | 02:53 PM
William's Avatar
William
Thank you ND! We appreciate your support for this hobby.
