Newbie Question
1. The Super Duty seems to have more rake then the dodge so I would be more inclined to want a leveling kit at the minimum; is there ever any long term issues with the Ford's by doing these slight adjustments? Any warranty issues here? What is the recommended leveling kit?
2. If I do put in a leveling kit would a 10-11,000 pound trailer on the hitch be enough to create sag? I dont want my headlights shining high when I am pulling the travel trailer.
3. I understand humans are more inclined to complain about things then praise these days so you read more stuff on the internet that is bad then good. The internet was rampant about Dodge's having weak front ends and ****ty transmissions (I upgraded to the Aisin transmission in my dodge for this reason); what are common issues in the current run of Ford Super Duty's?
Thanks in advance
As as far as ford concerns or things to watch out for, there are electrical connectors on the frame rails under the box of the truck that you have to add dielectric grease to. These connectors are not water tight and are known to corrode causing weird electrical issues. Also remove the 7pin trailer plug behind the bumper and add dielectric grease to that as well as it can cause a lot of warning codes. This simple preventative maintenance will save you dealer visits down the road.
You should also also look for leaks after a heavy rainfall. Some people have reported having a wet floor and water under the door sill plates. The door sill plates just pop off so it’s easy to check. All the reported leaks have been covered by warranty so it’s not a big deal.
If your infotainment screen on your instrument cluster defaults to the towing screen at start up, just select no active trailer and it will default to your last used screen. That’s a common thread for new owners.
Congrats on your our new purchase. What model did you get?
